Alaskan Benroy
Alaskan Benroy
Postby ratrod71 » Wed Nov 26, 2014 2:20 pm
Hello Fellow Teardroppers, my name is Bryan and I live in Fairbanks Alaska. I first introduced myself in the Newbie section, but I thought I would start an official "Build Journal", so please forgive the duplications of text and images. Here we go.
This is going to be a 4X8 with a Benroy side profile. 3/4" plywood floor and walls. Insulated roof. Manufactured side doors.
I built the frame using 2X2X.125" steel tubing. This includes the perimeter, cross-members, and tongue A-frame. These first pictures are when it is in raw steel freshly sandblasted, then etch primed, and finally topcoated with urethane single stage paint.
Raw steel and sandblasted.
Frame a.jpg (44.89 KiB) Viewed 7183 times
Primed with etching primer.
frame b.jpg (42.22 KiB) Viewed 7183 times
Topcoated with urethane single stage paint.
frame c.jpg (45.22 KiB) Viewed 7183 times
Alaskan Benroy build journal: viewtopic.php?f=50&t=61738
ratrod71
Alaskan Benroy
Postby ratrod71 » Wed Nov 26, 2014 2:26 pm
On the rear corners I welded a plate to accept the stabilizers. I drilled 3 sets of holes to give me options as to how they could be mounted. I.E. pointed back, at a 45 degree angle, or out to the side.
Stabilizer mounting plate at the rear of the frame
frame j.jpg (44.83 KiB) Viewed 7179 times
Stabilizer mounted at a 45 degree angle
frame k.jpg (46.16 KiB) Viewed 7179 times
Stabilizers in the down position
frame m.jpg (59.65 KiB) Viewed 7179 times
ratrod71
Alaskan Benroy
Postby ratrod71 » Wed Nov 26, 2014 2:30 pm
Completed rolling chassis.
frame i.jpg (55.04 KiB) Viewed 7179 times
frame e.jpg (63.89 KiB) Viewed 7179 times
frame d.jpg (57.34 KiB) Viewed 7179 times
ratrod71
Alaskan Benroy
Postby ratrod71 » Wed Nov 26, 2014 2:40 pm
For the axle I ordered a Dexter #9 built to the specifications I provided. Hub width is 60.5", mounting flanges are 43", the start angle of the swing arms is 10 degrees down, and the weight rating is de-rated to 1500Lbs. I called Dexter and talked with them about the dimensions that were needed. They then plugged the info into their computer program and e-mailed me the results so I could verify that everything would fit. Such as swing arm to the sides, wheel offset, and fender width requirements.
frame n.jpg (50.77 KiB) Viewed 7177 times
ratrod71
Alaskan Benroy
Postby ratrod71 » Wed Nov 26, 2014 2:48 pm
I am using 3/4" ACX plywood for the floor. The perimeter wood is clear poplar that was custom cut to 1 1/2" X 2" true dimensions. The floor will be channeled over the frame. This will give the plywood walls a strong surface to be glued and screwed to.
ratrod71
Alaskan Benroy
Postby ratrod71 » Wed Nov 26, 2014 2:55 pm
The screws used to attach the plywood to the poplar are coated deck screws with Torx bit heads. The fasteners used to hold the deck to the frame are 3/8" stainless button headed allen cap screws with nylon locking nuts. The glue used is Tite-Bond III.
Deck screws
Allen cap screws
ratrod71
Re: Alaskan Benroy
Postby KCStudly » Wed Nov 26, 2014 3:09 pm
Very nice! :thumbsup:
Welcome to the forum.
Images: 8119
Re: Alaskan Benroy
Postby noseoil » Wed Nov 26, 2014 6:16 pm
Welcome & want to see more! Looks like a good start on the build.
137905
noseoil
Images: 540
Re: Alaskan Benroy
Postby AlgoDan » Thu Nov 27, 2014 5:25 am
Welcome aboard Bryan, looking good and looks like you have a plan.
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Alaskan Benroy
Postby ratrod71 » Sun Nov 30, 2014 5:26 pm
I spent our snowy Fairbanks Sunday waterproofing the underside of the deck. I used the West System epoxy 105 resin, and 206 hardener. Applied 2 coats per their recommendation. I bought more than I needed, so I will be waterproofing the sides also prior to installing the aluminum skin. An inexpensive alternative to the West System foam rollers is the Wooster brand. Their foam roller named TIZ, part number R730, worked perfect and was purchased locally for less than half the price of West's. I know, the picture is kind of boring, but I thought I would throw it in. Happy Building, Bryan
Waterproofed deck using West System epoxy.
ratrod71
Alaskan Benroy
Postby ratrod71 » Sun Dec 28, 2014 1:06 am
I cut out the sides after drawing the arcs with compasses made from 1X2's with a screw in one end and a hole drilled in the other to accept a pencil. I used the exact dimensions shown in the "Generic Benroy" plan. The plywood is 3/4" birch. I am going to use pre-made 26"X36"doors. After cutting the sides out I used West System epoxy and coated the exterior side.
Freshly cut sides made of 3/4" Birch.
Cool little leftover corner pieces to be used to square up the side walls.
Laid out to coat with epoxy.
ratrod71
Alaskan Benroy
Postby ratrod71 » Sat Jan 03, 2015 8:56 pm
Today the deck got permanently mounted to the frame. I first put down camper topper foam tape on the frame prior to mounting the deck. This will keep the wood from chafing against the frame and make a waterproof seal. Then the sides were screwed into place. The mahogany spars are next including the framing of the opening for the Fan-Tastic Vent fan. Once evrything is mocked up and screwed into position, I will disassemble the spars and sides, then glue it up with Titebond III and permanently screw it together. This was a fun day!
ratrod71
Alaskan Benroy
Postby ratrod71 » Sun Jan 04, 2015 8:07 pm
Today the Alaskan Benroy got the roof spars and framing added for the Fan-Tastic Vent roof fan. :)
Roof vent spars and framing.
ratrod71
Re: Alaskan Benroy
Postby Redneck Teepee » Sun Jan 04, 2015 11:27 pm
Looks like things are coming together very nicely. Nice work too! :thumbsup:
Redneck Teepee
Images: 21
Re: Alaskan Benroy
Postby KCStudly » Sun Jan 04, 2015 11:59 pm
Looking good! :thumbsup:
Images: 8119
