Hi all!
My order of lights came in for the trailer! I now have 4 interior lights for the cabin, 4 side markers and 2 stop turn tail reverse combo lamps. I also picked up 2 black plastic 3" hole side vents.
I think 4 interior lights should be sufficient and plan to mount them in the ceiling so this makes wiring simpler. the only other lighting would possibly be 2 reading lights and I am on the fence about this. I may just pick up a couple more of the lights I ordered in and mount them lower and on a separate switch on either side of the cabin.
I need to get the interior wiring wrapped up in the walls so I can get the outside skin on. As far as the sides go I am looking into painting them. I would like some input on techniques that work the best. I know I don't want to have to worry about constant maintenance and the thought of moisture getting trapped in the wood. I could stain the sides too like the Wyoming Woody and do the fiberglass over that. Would it be best to fiberglass and then paint the sides? What paint is the best to use over fiberglass?
Thank you!
Jeremy
