Non-tongue tongue box
After much futzing around, the box for the front of the vardo is ready for paint.
I wanted something that looked a bit like a steamer trunk. I couldn't do the top as panels as that would collect water. Otherwise it came out much as I had hoped. Not all of the work is first rate, but it should suffice.
It will be mounted on two vertical boards low on the front of the vardo.
It has a latch that has a hidden ring at the bottom so that no lock is needed. The ring is held up by a small magnet so it is not at all visible from any reasonable angle. If a thief is determined no lock will suffice. If the thief is casual, this should do the trick.
The box will only hold the lawn tractor battery, the jack stands and related blocking, as well as waterproof odds and ends. Nothing of real value.
The box ready for paint.
Dry fit.
Gluing the lid down.
Open, showing latch but the fishing line down to the opening ring does not show up well.
It goes through a screw eye and through the bottom.
The latch ring released from its magnet.
click on pictures for better view.
John
