I finished off the trailer frame assembly last night, at least so far as the kit parts are concerned. I need to purchase and attach an appropriate jack, as well as attaching the stabilizer/jack things I purchased for my failed Cabinette build 8 years ago. The top bolts connecting the side rails to the cross-members present an obstacle to laying the floor flat on the frame, so I'm constructing a wooden mini-subframe for the floor to rest on yet clear the bolts.
The actual floor is ready to be installed after that's assembled and treated. It is resting atop sawhorses under the small shelter you can see at the edge of the first photo. I have to leave the shelter in the down position most of the time to prevent wind-related problems. I ran inside for bit last weekend and went back outside to find that despite concrete blocks sitting on a couple feet it had been been caught by the wind and blown half-over, with damage to one of the legs and a tear in the fabric. Now all the feet have concrete blocks and it stays down most of the time.
I've also completed assembly of the first wheel well, and the glue is drying. It will need to receive "the mix," paint, and caulk before it can actually be installed. The wood for the second wheel well is about half-cut.
