First build "Rocinante"
Postby HarleyCamper » Wed May 25, 2016 9:01 pm
I've been wanting to build a teardrop for a couple years now, ever since we had our oldest daughter. Camping was always a family summertime activity when I grew up and wanted to continue it with my own kids. Just picked up my NT 5x8 today and got the frame bolted together and squared, and axle attached.
Sent from my XT1080 using Tapatalk
HarleyCamper
Re: First build "Rocinante"
Postby HarleyCamper » Wed May 25, 2016 9:04 pm
I'm not familiar with the computer drawing programs, but have drawn blueprints.Image
HarleyCamper
Postby HarleyCamper » Thu May 26, 2016 7:58 pm
Got the rest of the frame bolted together tonight. I'd like to run the 13" wheels like I have on my utility trailer. Any input on the clearance between the tire and frame? Is it enough? I'm not planning on skinning down to the bottom of the frame. It'll be wood sided, even with the frame width. Inputs? ImageImage
HarleyCamper
Postby Greg M » Thu May 26, 2016 10:51 pm
Looking good. Just avoid those windmills ;)
Greg M
*Geek Extraordinaire
Images: 85
Re: First build
Postby noseoil » Fri May 27, 2016 7:33 am
Looks like enough, but keep the tires aired up well. Also, check for side-play under cornering loads, that's where you might have problems at speed. Major bumps on a corner might give it enough twist to push the top of the tire against the side.
If you had to, it might need a spacer or shim to change the offset a bit to get more room. Ours is a different type of trailer & has 2" side clearance. I like the 13" rims we run, just a bit better at highway speeds.
137905
noseoil
Images: 669
Postby HarleyCamper » Sun May 29, 2016 9:09 pm
I got the floor built today, 3/4" foam between 2 layers 3/8" ply.
HarleyCamper
Postby HarleyCamper » Thu Jun 02, 2016 5:00 pm
Vehicle wiring got done, bottom coated with asphalt paint and installed, and leveling jacks got installed. That should make it easier to work on. ImageImage
HarleyCamper
Postby HarleyCamper » Fri Jun 03, 2016 9:22 pm
"The mix" was applied to the edges, and the floor painted. I cut out the template for the walls with voids for insulation. Set it up the trailer to get an idea of the profile. Image
HarleyCamper
Postby HarleyCamper » Sat Jun 11, 2016 8:21 pm
Got the walls cut out and trimmed, though two router bits suffered bearing failure before I broke down and bought the 1/2" arbor 1/2" template cutting bit with two 1/2" bearings. It cut much better that the 1/4" and 1/2" single bearing bits it replaced. Image
HarleyCamper
Postby HarleyCamper » Fri Jun 17, 2016 9:51 pm
The ceiling is in, with much cringing and cussing with each creaking and popping off the Luan and difficulty getting it propped up while working alone. Built the gallery counter, and laminated it and the gallery floor with peel&stick vinyl tile. Coming together well.
HarleyCamper
Re: First build
Postby daveesl77 » Sat Jun 18, 2016 6:01 am
Looking really GREAT! And wow it is coming along quickly too!
dave
daveesl77
Images: 273
Postby Fishingtomatoseed » Sat Jun 18, 2016 6:40 am
The counter and sink looks good. I like the peel and stick idea.
Fishingtomatoseed
Images: 9
Postby HarleyCamper » Sat Jun 18, 2016 9:07 pm
Got some cabinet work done today. I'm starting to get anxious to finish! Too bad that's still a ways away.
HarleyCamper
Postby HarleyCamper » Sat Jun 18, 2016 9:08 pm
Thanks for the compliments. Lots of motivation around here.
HarleyCamper
Postby HarleyCamper » Sun Jun 19, 2016 7:42 pm
A productive weekend. Cabinet frames are built, and some painting done.
HarleyCamper
