New Build: Working title Glasshopper? Update: 4-2-17
Re: New Build: Working title Glasshopper? Update: 12-9-16
Postby Lagadelphia » Sun Dec 11, 2016 9:46 pm
KCStudly wrote:Looks pretty good!
I'm curious, are the spaces below and to the sides of the cubbies just lost space, or is there a plan for those areas? My thinking is that in a TD there really isn't any room for lost space.
I was going to leave it as lost space as it really isn't much really usable space there. The front panel is just screwed in so maybe I'll revisit that section.
Lagadelphia
Images: 5
Postby KCStudly » Mon Dec 12, 2016 7:24 am
Yeah, it wouldn't take much. Perhaps a hopper shaped tip out bin. I'm thinking maybe for a sock "drawer" or spare face towel. Maybe not worth the effort depending on your style of camping, but if you're not sure what you want yet, as long as you keep your options open you can't go wrong, right? :lol:
Images: 8119
Postby Lagadelphia » Mon Mar 20, 2017 10:02 pm
So I've been neglecting to update my build journal. I've been working non stop on the trailer so the project didn't stall :) Without further ado, the pictures:
Lagadelphia
Images: 5
Re: New Build: Working title Glasshopper? Update: 3-20-17
Postby Greg M » Wed Mar 22, 2017 11:10 pm
Is that a standard luggage hatch for the air conditioner?
Greg M
*Geek Extraordinaire
Images: 85
Postby Lagadelphia » Thu Mar 23, 2017 11:25 am
Greg M wrote:Is that a standard luggage hatch for the air conditioner?
I used this: https://www.amazon.com/Seaflo-Marine-Ac ... rine+hatch
Lagadelphia
Images: 5
Postby tac422 » Thu Mar 23, 2017 12:40 pm
Looks Great !
What did you use to trim the outside edges ?
tac422
Images: 222
Postby Lagadelphia » Thu Mar 23, 2017 1:48 pm
I used 1 inch aluminum angle for the corners, 1.5 in aluminum flats around the bottom of the trailer, and 1 inch flats on the nose. Got it all from Lowes
Lagadelphia
Images: 5
Postby working on it » Thu Mar 23, 2017 2:09 pm
How are you going to seal the A/C unit, to prevent leaking air from inside to outside and vice-versa, sliding it back and forth? I see no seals on the sides, none over the top, and the sliding tray presents no true sealability, with the sliding track area open at both ends.Even if you attach the normal expandable accordion seals to the sides, you'll still have to re-adjust them upon moving the unit. Same goes for however you affix sealing strips to to and bottom. I would use rubber fender welting in place of the metal/plastic ends of the accordion seal, and possibly on top and bottom, too. Or door sweeps or shower door bottom seals? I mounted my A/C permanently in a bulkhead, sealing it there with several layers of foil tape, just so I wouldn't have to worry about getting a good seal whenever moving it about. However, that became a moot point when I decided to seal it entirely within the closed trailer, running it without the hatch open at all (I never thought of the mini-door you have for yours).
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2150+ lbs
156215157958148599
working on it
Images: 455
Postby Lagadelphia » Thu Mar 23, 2017 3:05 pm
That is still an issue I have to work out. I had thought about finding a piece of edpm pond liner and cutting a square our of the middle smaller than the outside on the ac u it so it made a seal around it when it is pulled out.
I am thinking for an immediate working solution cutting pieces of my left over insulation to fill the gaps. Not an elegant or attractive solution but it'll get me on the road.
Lagadelphia
Images: 5
Postby tac422 » Thu Mar 23, 2017 4:00 pm
I use 3 pieces of black packing foam cut to size, (both sides and the top) and fit them whenever I pull the AC out.
I'll see if I can find a picture.
Found it here :
search.php?keywords=refrigerator&t=56441&sf=msgonly
tac422
Images: 222
Postby Lagadelphia » Sun Apr 02, 2017 7:11 am
tac422 wrote:I use 3 pieces of black packing foam cut to size, (both sides and the top) and fit them whenever I pull the AC out.
Found it here :
Thanks for the idea. This is what I ended up doing. I still had a bunch of the stuff from my window packages.
Lagadelphia
Images: 5
Re: New Build: Working title Glasshopper? Update: 4-2-17
Postby Lagadelphia » Sun Apr 02, 2017 7:14 am
147614
First hook up and two laps around the block. It didn't fall apart so it was a success!
Lagadelphia
Images: 5
Postby Lagadelphia » Mon Apr 03, 2017 9:57 pm
147628
147627
Cushions are in 6 in of HD foam and two inches of memory foam. I have to cover the one piece. I needed it to support the front of the cushion when I made it into a couch.
Lagadelphia
Images: 5
