It's 3mm solid core. It bent really nicely along the roof. The corrugated core material would work well for walls, or if your roof is flat, but it will not bend well.SLO_Ken wrote:Is your ACM the solid core type, or the hollow core? How thick? I've been considering using ACM in place of plywood when I finally get around to building up my trailer. Seems like a fairly ideal material, if a little expensive upfront.
Thank you. It's been a long process.clamlamp wrote:I stumbled upon this build journal when you asked about the door install orientation. Great job!
Brett,bnicho wrote:Hi,
I have been following this thread with great interest, as I am also looking to use ACP in my build.
Where did you surce the router bits to use on the ACP? Are the bits special ACP bits or just standard wood or aluminium ones?
Thanks,
Brett
Users browsing this forum: No registered users and 31 guests
