Chesapeake Light Craft Teardrop Trailer
Re: Chesapeake Light Craft Teardrop Trailer
Postby Pmullen503 » Fri Jan 06, 2017 12:40 pm
You can use hot melt glue to glue blocks with hooks the inside of the door pieces to allow you to pull them into place with straps while the epoxy sets up. Later you can just pop them off or use some alcohol to loosen the blocks if you get carried away with the hot melt.
Pmullen503
Images: 67
Postby friz » Fri Jan 06, 2017 12:54 pm
Pmullen503 wrote:You can use hot melt glue to glue blocks with hooks the inside of the door pieces to allow you to pull them into place with straps while the epoxy sets up. Later you can just pop them off or use some alcohol to loosen the blocks if you get carried away with the hot melt.
Thanks for the tip.
The "Sin Bin"
150133
friz
Postby lthomas987 » Fri Jan 06, 2017 3:35 pm
friz wrote:I got a case of Canadian trailer spacers in the mail today.Image
Sent from my Altair 8800 using Tapatalk
I always thought they were dog toys. :) Who knew they were trailer spacers!
I am really enjoying your build.
Sent from my LGLS991 using Tapatalk
Laura
lthomas987
Images: 204
Postby capnTelescope » Fri Jan 06, 2017 11:25 pm
OUTSTANDING! Fantastic job, Friz. :thumbsup: :applause:
Sent from my SWTPC-6800 using 110 Baud. :roll:
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby pohukai » Sat Jan 07, 2017 1:14 pm
I'm clueless as to the purpose of these "trailer spacers". What are they used for? Googling the term doesn't yield an answer.
pohukai
Images: 9
Postby friz » Sat Jan 07, 2017 6:09 pm
The camper shell of my build has a spine of sorts that runs the length of the bottom. Also the trailer has bolt heads that I don't want cutting through the finish on the bottom.
The "Sin Bin"
150133
friz
Postby friz » Sun Jan 08, 2017 2:38 pm
A weekend of sanding and working gaps.
The "Sin Bin"
150133
friz
Postby friz » Sun Jan 08, 2017 7:15 pm
The "Sin Bin"
150133
friz
Postby friz » Sun Jan 08, 2017 8:54 pm
Longer weekend then I thought it would be. 8pm Sunday night. Miller time.Image
The "Sin Bin"
150133
friz
Postby friz » Mon Jan 09, 2017 11:32 pm
The "Sin Bin"
150133
friz
Postby justlisawv » Tue Jan 10, 2017 12:40 pm
This is just gorgeous.
"Bare Bones" teardrop purchased from Rustic Trails Teardrops.
144762
justlisawv
Postby friz » Tue Jan 10, 2017 1:15 pm
justlisawv wrote:This is just gorgeous.
Thanks Lisa,
Chesapeake Light Craft's kits are pretty hard to screw up. I am assuming from your handle, that you are in West Virginia. Annapolis MD can't be too far for you, you should drop in on them sometime.
The "Sin Bin"
150133
friz
Postby friz » Tue Jan 10, 2017 6:59 pm
Fit seems good. Time to glue.
The "Sin Bin"
150133
friz
Postby friz » Tue Jan 10, 2017 10:17 pm
The "Sin Bin"
150133
friz
Postby friz » Wed Jan 11, 2017 8:28 pm
I took some extra steps to insure a good door fit. Seems to have paid off.ImageImageImage
The "Sin Bin"
150133
friz
Users browsing this forum: Google [Bot] and 8 guests
