Australian Retro Rambler
Re: Australian Retro Rambler
Postby edgeau » Fri Jul 28, 2017 9:38 pm
Shelf in. Wiring done and insulation installed! Almost time for the roof....
Sent from my Pixel using Tapatalk
edgeau
Postby edgeau » Sun Jul 30, 2017 4:01 am
Roof 1/2 on before I ran out of day...Image
edgeau
Postby edgeau » Sun Jul 30, 2017 7:24 pm
Here is a trick that proved invaluable. I put some masking tape on the outside so I could mark where each spar is. Then I ran a string line on the centre of each to ensure the screws hit a spar.ImageImage
edgeau
Postby edgeau » Fri Aug 04, 2017 8:51 pm
And here is it working...
edgeau
Postby edgeau » Sat Aug 05, 2017 10:21 pm
After removing the straps I noticed a little bit of veneer cracking right at the end of the bend on one side. I hope a sand a a few more coats of varnish will sort that out.
edgeau
Postby edgeau » Sun Aug 06, 2017 2:22 am
Also got the hatch cut outImage
edgeau
Postby edgeau » Sat Aug 12, 2017 11:57 pm
Progress this weekend includes
Stoneguard layer on the front, hood for where the electrical wiring emerges, and the overhang on the roof trimmed with the router.
edgeau
Postby edgeau » Sun Aug 13, 2017 12:07 am
Wiring hood
edgeau
Postby edgeau » Sun Aug 13, 2017 12:11 am
Trailer attachment legs made from recycled motorcycle shipping crate. I cut sheet metal and bent over the wood. The 45 deg bevel will help to slide down the edge of the trailer if it is not quite possitioned perfectly.
edgeau
Postby edgeau » Sun Aug 13, 2017 12:13 am
The trim bit was a bit too close and took some varnish off. A reapplication looks good in most spots. Some will need more coats.
edgeau
Postby edgeau » Wed Aug 16, 2017 3:29 am
Today I installed the vent and added a strip of ply down the centre line to seal the butt join between the roof sheets. A cove bit on the end made it fit nicely over the rounded edge of the stone guard board.
I would have preferred a darker color for the vent. Perhaps I'll find a suitable paint for plastic at some stage. ImageImageImageImageImageImage
edgeau
Postby edgeau » Thu Aug 17, 2017 5:49 am
Another coat of stain...
edgeau
Postby edgeau » Wed Sep 06, 2017 6:17 am
It has been a challenge lately to find time to "make sawdust" but I finally started framing up the kitchen area tonight. It was pretty slow because I don't like using power tools at night so I was doing rip cuts with a hand saw!
.ImageImage
I have also completed my trailer attachment legs that will let me unbolt from the trailer and reattach easily. The piece of plywood with the T nuts has been glued on the inside of the rail so I don't need a socket or spanner behind
edgeau
Postby edgeau » Thu Sep 14, 2017 4:54 pm
Well the bulkhead and bench are in. On to the fridge slideImageImageImageImageImage
edgeau
Postby edgeau » Sat Sep 23, 2017 2:08 am
Well the fridge slide worked fine but there was a measurement problem. I forgot it has a gas fitting sticking out the back! Doh! So there is now a cut out in the bulkhead to accommodate it. I'll construct a little box to seal it off from the interior after I finish the hatch.
edgeau
