We have started
We have started
Postby PJLangevin » Sat Aug 12, 2017 12:03 pm
I have introduced myself in the newbie area. Started on our build journey this weekend. Kinda cheated by buying a partially done teardrop. See the pictures below. So this weekend is covering front and roof with plywood. So after reading a lot on this forum, decided to by 1/4" Wobble wood for front curve. Going with long bend, with 1 seam down the front as teardrop is 60" wide. Going with Titebond 3 for the wood & Elmer's Ultimate for wood to Styrofoam.
150232 150231
More pictures to come tomorrow hopefully
An it harm none, do what ye will
PJLangevin
Images: 18
Re: We have started
Postby edgeau » Sun Aug 13, 2017 4:59 pm
Good luck. How did you find a partially built one? Was that a plan or just an opportunity?
Sent from my Pixel using Tapatalk
edgeau
Re: We have started
Postby PJLangevin » Mon Aug 14, 2017 9:43 am
It was on kijiji, was looking for a utility trailer, and it popped up. The builder inherited a truck camper so decided not to finish it. It needs roof, front skinned (finished that this weekend). Was the walls, and almost all major construction done on a trailer already.
PJL
PJLangevin
Images: 18
Re: We have started
Postby Aviatorbrew » Mon Aug 14, 2017 7:20 pm
cool!
Andy & Mandy's Luv Shack!
64" x 12' standie, "under construction"
2018 4 runner
2007 tacoma 4 dr 4wd
Aviatorbrew
Images: 25
Re: We have started
Postby PJLangevin » Wed Jun 06, 2018 8:44 pm
Bit of an update on where we are with this.
154752154751154750154749154748154747154746
Need to build doors, everything is covered with 2 coats of Raptor BoxLiner White, Plum Crazy Purple will be added to strips. Interior work is next and to flesh out the Galley.
It is heading to British Columbia on June 3oth, so I need to get busy.
PJLangevin
Images: 18
