Photophobic retreat
Photophobic retreat
Postby Photophobic » Sat Nov 11, 2017 9:48 pm
It begins!
I picked up my trailer this week, way beefier than I expected, a great deal heavier than what most people are building on but it adds peace of mind that it won't break on fire & logging roads.
151678
I had brakes put on from the start, covers me no matter what state I go to and won't ever wish I had stopped slower. Springs are what they put on for ATV trailers so I should be good for any forest roads I come across.
151679
Paul
Photophobic photographer looking for adventure.
Follow my build thread Here and all my adventures on Instagram
View my work & learn more about what we can do for your business at https://www.paulbrousseauphotography.com
Photophobic
Images: 20
Re: Photophobic retreat
Postby Shadow Catcher » Mon Nov 13, 2017 6:41 pm
Looks like a good start. Just remember you are building an airplane, not a tank :thinking: despite the frame.
Images: 200
Postby Photophobic » Tue Dec 05, 2017 1:02 am
Shadow Catcher wrote:Looks like a good start. Just remember you are building an airplane, not a tank :thinking: despite the frame.
Good thought to keep in mind but I was always fond of the B-17, overbuilt, sure but took a beating and brought her crew home when nothing else could have.
Paul
Photophobic
Images: 20
Postby Photophobic » Sun Jan 07, 2018 12:26 am
Low temperatures forced me to haul the floor inside to paint the underside. Dry and back on the trailer (this side down) I can start building the walls onto it.
Paul
Photophobic
Images: 20
Postby Photophobic » Thu Jan 11, 2018 6:58 pm
Back in the garage and bolted down. It probably doesn't look like a lot of progress but it was a good amount of work. I think I did it the hard way, by drilling the bolt down holes in the frame first and then trying to match the holes in the floor to them but I didn't want to risk drilling the wrong part of the steel frame.
The second 2x4x10s are the base of the walls, they're spaced for the outer ply from the fenders and the carriage bolts will remain exposed as part of removable teardrop box from utility trailer design.
Paul
Photophobic
Images: 20
Postby Photophobic » Mon Feb 05, 2018 6:11 pm
Other members feedback got me thinking about the idea of side doors in addition to my rear entry and although I'm not sold on all of their reasons I've gone ahead and cut them out and will attempt to build them myself. I can't afford commercial doors so its going to add quite a bit of labor but having an secondary escape route in case of emergency was a pretty strong selling point.
152908
With both walls cut and framed they stand on their own and are ready for roof bows to start going in. When my canvas arrives I'm going to check my gap on the wheel well again before cutting the roof bows just in case i need to slide the walls in a hair.
152909
My inside wall panels are cut to this same shape but will need to be trimmed along the bottom and notched for the roof bows before getting their final fit.
Paul
Photophobic
Images: 20
Postby Photophobic » Wed Mar 07, 2018 5:47 pm
Forgot to upload this before, the shape has come along and a test bend around the front was easy. The roof bows support me pulling myself up easily (might have to mount some handles if i get to used too it) with less wobble than going up the stairs on a number of factory TTs I had looked at.
153378
I was hoping to show off my Galley hatches this week but the ribs didn't hold the curve so I'm off to Home Depot to pick up some sheathing plywood to cut new ribs. Fingers crossed they hold or I may be looking at a considerable redesign.
Paul
Photophobic
Images: 20
Postby Staryder61 » Wed Mar 07, 2018 7:05 pm
Great start Paul, :)
You sir are on your way..
I too had a trailer built, and I'm glad I did,, little more beefier then some use.. ;)
But, like the peace of mind, (Not going to collapse going down the hi-way)
David
David
"A Great Mind is like a Parachute, it works best when it is open.."
"Our build Journal.." http://www.tnttt.com/viewtopic.php?f=50&t=69528
staryder61@gmail.com
Staryder61
Images: 291
Postby Photophobic » Wed Mar 07, 2018 11:23 pm
Thanks David,
The beefy trailer is a huge piece of mind, most small cars can;t hurt that frame and if my construction falls apart on a trip I know i can strap everything down until i get o the landfill. :lol:
Paul
Photophobic
Images: 20
Postby Flatworm » Thu Mar 08, 2018 2:16 am
I was worried about doors too. However, I found them easier than expected. Just make allowance for foam tape around the internal frame. I'm pleased with my Wiley windows so far. Very fast and cheap to make.
Flatworm
Images: 80
Postby Staryder61 » Thu Mar 08, 2018 9:57 am
Paul,
Constructions looking good,, :thumbsup: I don't believe there'll be any trips to the landfill... :)
Keep the pictures :pictures: coming as you move along...
What are your plans for the outside finish? :thinking:
Door is a worry for me too flatworm,
David
David
Staryder61
Images: 291
Postby clamlamp » Mon Mar 12, 2018 8:20 pm
Great work! following your build!
clamlamp
Postby Photophobic » Wed Mar 14, 2018 9:42 pm
I've decided I definitely want to add marker lights for both cosmetic and safety reasons. I don't think the minimum that came on the trailer are necessarily enough (even if I don't get a ticket) and the only limitations I could find were that I probably shouldn't (probably not a ticket if i do but unclear) have the 3 ID lights in the center since I'm under 80 inches. A few extra lights look good but being photophobic I don't want to blind myself in the rearview mirror.
Front & Rear renderings of what I plan to do:
153502 153503
The lights I have in mind are pretty low profile so I'm not sure how visible the ones along the curves will be from the sides but they looked funky when mounted on wall.
I might put a couple more red on the back (I'll have extras and the wire will already be there) but with the long brake lights added on the galley doors I think my visibility will be plenty improved without them.
There will (probably) be a porch light over the side doors but it won't be on going down the road so I haven't bothered to render it these.
Paul
Photophobic
Images: 20
Postby Photophobic » Wed Mar 14, 2018 9:50 pm
Staryder61
I'm going with PMF, I'm not sure I'll like the texture and it might show more than I'm hoping but it seemed to me to be the most forgiving for a first time builder. My woodworking skills would not make a beautiful woody like you see on other people's threads and aluminum is way out of my price range (and no experience working with it).
Paul
Photophobic
Images: 20
Postby Staryder61 » Fri Mar 16, 2018 8:15 am
Paul, have seen a lot of the ones that were done PMF on here.. once painted they look great, the texture is not noticeable.. :D
David
Staryder61
Images: 291
