My (re)Build journal. 5x10 ( Updated 5/5/18)
Re: My (re)Build journal. 5x10 (1/10/18)
Postby aggie79 » Wed Jan 10, 2018 4:46 pm
:thumbsup: :applause: :thumbsup:
Postby Staryder61 » Thu Jan 11, 2018 12:54 am
Thanks jsn, I'm hanging in there.. feeling better and got a short break in the weather..
TD deck built and sealed.. ready to flip and start working on cabin...
You are moving right along on yours.. :thumbsup: :thumbsup: amazing looking.. The galley is turning out really good. :D Outstanding workmanship... :thumbsup:Are you able to use the old diamond plate fenders?
You're going to enjoy it so much when the weather permits..
Stay safe, David
Our CTC
6' X 12' CTC = Texas Sized Tackle Box
Staryder61
Images: 528
Postby jsnbergman » Thu Jan 11, 2018 8:36 am
:oops:
aggie79 wrote::thumbsup: :applause: :thumbsup:
Thank you! Your work and participation on the forum has been a true asset in my build.
Staryder61 wrote:Thanks jsn, I'm hanging in there.. feeling better and got a short break in the weather..
Glad your feeling better. It was 60 here last night so I wheeled the trailer outside so I could blow off the sawdust and sweep up the garage. Of course were under a winter weather advisory this afternoon and it will get down to 15 :x
I weighed the hatch this morning and going to run the strut calcultor and get those ordered up. Think i want to get those set b4 cabinets. Want to maximize the space for the cabinets.
The original fenders were just flat diamond plate bent in an arch with a rubber strip on the edge. I think i am ordering smooth aluminum fenders. I have a good chunk of unused plate from the original trailer that will probably find its way into other projects. Or my off road tdrop im building in my head.
jsnbergman
Images: 16
Postby Staryder61 » Fri Jan 12, 2018 11:51 pm
Crazy weather jsn,
Glad you had a heat wave and could move it outside for a time. :)
For the area I live, this winter has been the coldest this year I have seen since the early 80's. Now they're saying by next Tuesday we will be down in the teens..
Feels like someone lassoed us and pulled us up north. :( Had lived in Indiana for a few years. So we know about the winter advisory's..
Today decided to work on the accent lights for under the trailer frame. Linda (my better half loves purple) so I ordered purple. So spent the biggest part of the morning. Cutting wire, splicing, soldering, all the purple lights together.. She'll love it.. :thumbsup:
Then started on the cabinet lay out drawing.. a lot to figure into a small space...
Stay safe, David
Our CTC
Staryder61
Images: 528
Re: My (re)Build journal. 5x10 (1/17/18)
Postby jsnbergman » Wed Jan 17, 2018 11:03 am
Ran some wiring while waiting for the UPS guy, who decided to not show up till 8pm with my struts. Got my fuse block and switch panel wired in the right cabinet. The light was installed when I built the hatch but got the wiring finished. Really liking it, just routed an edge out of a 1x3 and tucked the LED strip in it. Lights up the galley nice with the hatch open. The struts took 1 relocate as I didnt clearance the cabinets. After moving them they are a tad strong but close nicely, a slight latch adjustment and I should be able to get them to catch unassisted.
jsnbergman
Images: 16
jsnbergman
Images: 16
Re: My (re)Build journal. 5x10 ( Updated 1/17/18)
Postby Staryder61 » Wed Jan 17, 2018 4:25 pm
Js,
the light turned out really good.. :thumbsup: what weight did you get on the struts..? :thinking:
Stay safe, David
Our CTC
Staryder61
Images: 528
Postby jsnbergman » Sun Jan 21, 2018 1:16 pm
Staryder61 wrote:Js,
I think they were 110, but ill check my amazon. They were perfect when I had them at my initial position but I had to move them back to clear the cabinets. I didnt take in the diameter of the strut itself and it barely hit the cabinet. If you havent seen the strut calculator thread do a search, its perfect. If you cant find it Ill send you the excel.
They still open great and I can let go of the hatch at they are smooth. Even help close once it gets to the bottom.
jsnbergman
Images: 16
Postby Staryder61 » Sun Jan 21, 2018 5:20 pm
Thanks js,
I'll look for the strut calculator thread.. I've finally had more time, and the weather has been co-operating to get more done on the Raven.. :thumbsup: :thumbsup:
Working on the side walls. Cutting holes for insulation and windows.. :D
Stay safe, David
Our CTC
Staryder61
Images: 528
Postby jsnbergman » Sat May 05, 2018 4:32 pm
havent been on in a while and progress was slow because of the stupid winter that wouldnt end. Been able to get some work done in the last couple weeks. Fenders, some more work in the galley, windows set in and door seals done. Mostly wrapping up some odds and ends that I didnt want to do in the cold. Ill upload some more progress photos when I get her back in the garage and cleaned up a bit. Couple weeks till the maiden voyage, Jeep Blitz in Bushnell IL!!!
facebook_1525543010149 (1).jpg (61.64 KiB) Viewed 2655 times
jsnbergman
Images: 16
Re: My (re)Build journal. 5x10 ( Updated 5/5/18)
Postby jsnbergman » Mon May 07, 2018 12:33 pm
The galley is just about finished, will be adding a drawer in the center. It will be pretty wide but only making it 10" deep. will be good for utensils. Also going to add bottle holders along the back wall in between the plate holder and the cabinets. Should be able to fit a couple 1/5s on each side.
jsnbergman
Images: 16
Postby Staryder61 » Mon May 07, 2018 5:00 pm
:thumbsup: :thumbsup: Galley looks awesome, love the colors. Very retro looking to me.
Have you considered adding a bottom to the camp stove pullout, (storage for pots or pans etc.), just a thought :thinking:
Stay safe, David
Our CTC
Staryder61
Images: 528
Postby Woodbutcher » Mon May 07, 2018 5:07 pm
Looks great, nice job! :thumbsup:
Woodbutcher
Postby jsnbergman » Mon May 07, 2018 8:47 pm
Staryder61 wrote::thumbsup: :thumbsup: Galley looks awesome, love the colors. Very retro looking to me.
There actually is one, its lined with the checkerboard so its hard to spot. After a couple trips we might add another shelf to it, but wanted to see what we needing first. We have a griddle that is the size of the stove that for sure needs a spot.
jsnbergman
Images: 16
Postby Staryder61 » Mon May 07, 2018 11:01 pm
Jsn, Wow, yep it's there hiding,, I did miss that bottom,, :D
Stay safe, David
Our CTC
Staryder61
Images: 528
Users browsing this forum: No registered users and 26 guests
