Benroy for my baby
Re: Benroy for my baby
Postby clamlamp » Sat Apr 14, 2018 5:15 pm
tony.latham wrote:
clamlamp wrote:
tony.latham wrote:
Got mine from McMaster Carr.
And McMaster is really good about returning them for stronger or weaker ones.
What's a good pound rating to start at Tony?
Sent from my ONEPLUS A3000 using Tapatalk
Plug your numbers into the XL file from this thread: :thumbsup:
http://www.tnttt.com/viewtopic.php?f=21&t=58263
I believe my 56-pound (!) hatch took two 120 pounders. They sure work well.
Thanks Tony! :beer:
clamlamp
Postby willrothfuss » Sat Apr 14, 2018 8:06 pm
Paul it's looking great! Nice work on the hatch!
I see you did PMF on the tongue box. Will that get a piano hinge? I had this idea for a flap on the front where you have your window that lifts up to make a sort of an awning and open a screened window, if you can imagine that. Sort of like the older designs from the 30s. I was wondering if it would work to install the hinge first. protect it with a strip of tape and then sort of PMF over the entire thing so the PMF went right over the hinge to the "door" (awning) to protect it all from water. Sounds a little iffy- I'd have to do some sort of mock up. You could then take it apart and remove the tape. Maybe the best idea would be to PMF everything first, then install the hinge and a fabric strip over that.
Well, it's one of those ideas that will bounce around in my head for a while.
Will
Do not go where the path may lead, go instead where there is no path and leave a trail. Ralph Waldo Emerson
willrothfuss
Postby clamlamp » Sun Apr 15, 2018 5:38 pm
willrothfuss wrote:Paul it's looking great! Nice work on the hatch!
Will
I don't think using a fabric seal will do a good job because it needs to flex to cover the hinge and pmf doesn't flex well and once the paint is on, it'll flex even less.
I am going to do a piano hinge for the tongue box. Initially I was going to just put a piece of wide rubber underneath but I read people use bicycle tires to wrap the piano hinge. I also found this video on youtube which gave an interesting weather seal.
https://www.youtube.com/watch?v=O1W9ETnmDpk
clamlamp
Postby tony.latham » Sun Apr 15, 2018 6:04 pm
When I built my tongue box, I used one of the plastic living hinges. "UV-resistant." It didn't last many years.
This is the low-profile hurricane hinge I replaced it with:
It stays dry.
George at the Teardrop Fix-it Shop in Montana sells them.
Postby clamlamp » Sun Apr 15, 2018 6:16 pm
tony.latham wrote:When I built my tongue box, I used one of the plastic living hinges. "UV-resistant." It didn't last many years.
It stays dry.
Tony,
Do you use butyl tape under the galley hinge and tongue box hinge?
clamlamp
Postby clamlamp » Sun Apr 15, 2018 6:19 pm
3 coats for silver exterior semi gloss paint. I have a headache from the fumes but at least I'm ready for for and window installation! Just curious if butyl tape is what everyone uses to seal their doors and windows?ImageImageImageImage
clamlamp
Postby tony.latham » Sun Apr 15, 2018 6:48 pm
I do, without any issues.
I attach the hinge on the hatch first with poly sealant. But the front of the hinge with the tape. Makes for an easier install.
Your finish looks great, BTW.
Postby clamlamp » Sun Apr 15, 2018 10:45 pm
Thanks Tony!
clamlamp
Postby clamlamp » Tue Apr 17, 2018 12:24 am
YouTube is telling me to use lap sealant around my vent fan along with butyl tape for RV. Does this apply to teardrops as well?
clamlamp
Postby tony.latham » Tue Apr 17, 2018 9:34 am
I use butyl tape under the vent fan. It's a moving part and thus someday, it'll fail and need replacement. I don't think it'd be fun pulling one that is sealed with polyurethane sealant.
I haven't had any leaks. It's what Grant used with his Little-Bear teardrops and that's what sold me on it. Lap sealant? Might be a good idea but I haven't used it.
Postby clamlamp » Tue Apr 17, 2018 10:27 pm
Was able to work on some of my electrical. I connected the solar charger directly to the battery by passing the main power switch. But now I am questioning should it be all connected to the main battery cutoff switch. Also there is nothing connected to the load terminals on my solar charger and I'm not sure if I should be using them. I still need to wire up the rear Galley and do all the waterproofing around the Windows Doors vent and install the hinges.
For my issue with the wheels I ended up using a 5mm Universal spacer that brings out my wheel to about an inch which has salt all my issues.ImageImageImageImageImageImageImage
clamlamp
Postby clamlamp » Tue Apr 24, 2018 12:15 pm
Not much progress because my student made it to state woodworking competition for skillsusa. Unfortunately he didn't place but he is a winner for just making it up to that level.
Took the advice of Tony Latham and poly sealed the hatch side of the hurricane hinge and butyl taped the rest. Hatch ended up being 40lbs.
Had issues with the wiring for the 4 pin connector. Somewhere 3 of the 5 i ran to the rear hatch are grounded so I have to run wires underneath now... What a pain... Took a long time diagnosing why my signal lights weren't working.ImageImageImageImage
clamlamp
Postby clamlamp » Wed Apr 25, 2018 8:24 am
Spent the day yesterday painting the graphics. Most of that time was taping it up.ImageImageImageImageImageImageImageImageImage
clamlamp
Postby tony.latham » Wed Apr 25, 2018 10:38 am
Holy-Moly, that thing's looking good!
:pictures:
T
Postby tiiiiii85 » Wed Apr 25, 2018 12:43 pm
It's so cool!! It looks like it has a face. :)
Sent from my ONEPLUS A3003 using Tapatalk
tiiiiii85
