Sent from my ONEPLUS A3000 using Tapatalk
KTM_Guy wrote:Nice shop you have there.
I joined the two pieces of plywood using my Domino.
Ya i was cutting 1\8" at a time but the but height was only 3\8". I didn't have a roto tool or a Dremel with a correct bitStaryder61 wrote:clam,
for an 1/8" cut. Next time, sounds like a roto-zip tool might make the route easier.. using the 1/8" collet and a 1/8 in. Saber Cut Wood Bit. Can have a depth cut of 1" thick..
From experience, make multiple passes, setting the depth deeper with each pass with the roto-zip to get the depth required. It would (does) give a clean cut.. I have used this technic to make cut-outs in counter tops (plywood or HD particle board) for kitchen and vanity sinks.. where a jig saw or larger router base had no clearance between the route and the back splash..
Thanks daveesl77! Glad to have you on this adventure!daveesl77 wrote:Really, really nice work! I love the Benroy shape, you get the curves, but also get additional room. Fun following your build.
dave
So those who have done the Steve frederick style galley after cutting out that piece to use sanded smooth or leave as-is so it sits at even spacing along the whole side?
do you finish the interior walls or exterior before assembly or wait for spars to go in?
