The first road trip...
I got new tires for it, even though the old ones had good tread, they were 10 years old, and I didn't want that to be the reason I ended up on the side of the road out in the desert. The morning of the departure, I was still working on many details, including making the electrical panel, the aluminum pins for the galley doors, packing everything, etc. My old college roommate and I got under way and as I nervously drove off, I was watching carefully in the side mirrors for signs of the camper coming loose. It's only held down by four 1/2" bolts that go through a piece of fir in and through the stake posts. The truck handled very well, and had good power, at least on flat ground. We made it onto the freeway, and even got up to 70mph, although hills required downshifting into 4th and occasionally 3rd gear, which isn't a surprise for this truck. I can forget about using the AC on anything even slightly uphill. I checked the bolts at every stop and found no signs of loosening.
I'm going to try to weigh it one of these days, I'm guessing it will come in at around 500-600lbs. I can easily lift one end when it's not bolted down, and I can still pull it out by myself, although it's a struggle.
It got lots of looks on the road, I saw some people take pictures. I figure there were a lot of "what was that guy thinking?" comments, but I got some thumbs-up too. This might be one of the more unique campers out there!
Mid Hills campground, Mojave National Preserve:
- 20180324_191259 copy 4.jpg (143.34 KiB) Viewed 2991 times
The 30 mile or so dirt road to the campground provided a new reason to be nervous, the jarring made me worry that the whole thing might work itself apart. The structure is pretty strong, it's a integral unit wrapped in canvas and glue, which helps add a lot to the strength. Everyone wanted to see what this thing was about... I was camping with a bunch of geologists I'd known in college, and a couple of professors too.
- image004 copy 3.jpg (95.36 KiB) Viewed 2991 times
All of this stuff fits in below the benches. I didn't use the legs, since the picnic table was handy. I used a 413F instead of a heavier 3-burner. I didn't want to chance beating up the 443 yet. The "modern" bent wire wind wing catches on the 413F and newer stoves is really nice to have instead of the wiggly wire arrangement. The lid stayed up the whole time in pretty gusty wind conditions. There's a flip-up table between the two boxes, and a flip-down lid on the left box.
- 20180324_150737 copy 3.jpg (161.34 KiB) Viewed 2991 times
