2+2+1 ish
Re: 2+2+1 ish
Postby Jordan87 » Sun Jun 24, 2018 8:49 pm
Got a lot done this weekend.!ImageImageImageImageImageImage
Sent from my SM-J700T1 using Tapatalk
Jordan87
Re: 2+2+1 ish
Postby KCStudly » Mon Jun 25, 2018 10:30 am
I sure hope that you have checked to make sure your hatch swings away from your wall and is not hooked under it. The further you go w/o verifying this critical issue, the more work that will have "passed under the bridge".
Simple as pinning, or taping, a string to your side wall at the hinge point and seeing if the radius of the lower most edge of your hatch swings by the profile turning at the hinge.
It will really suck if you build your hatch and can't open it.
Images: 8116
Re: 2+2+1 ish
Postby Jordan87 » Mon Jun 25, 2018 10:42 am
I put a simple hinge on it and it seemed to work fine. I noticed a slight tight spot that I believe a bit of sanding will fix. Other than that it seemed to work fine.
Jordan87
Re: 2+2+1 ish
Postby KCStudly » Mon Jun 25, 2018 12:08 pm
:P :worship: I'm so relieved for your sake.
Believe it or not, but that has caught people out before.
Images: 8116
Re: 2+2+1 ish
Postby Ge99ne » Fri Jul 06, 2018 1:42 pm
Wow that tail is a tight fit. I love the profile. You had to take a couple of feet off of you plan? The curves are very smooth.
Ge99ne
Re: 2+2+1 ish
Postby Jordan87 » Sat Jul 07, 2018 10:23 am
I actually originally thought I would but was able to adjust and keep the 12 feet. I did slope out the back a bit less though to gain a bit more headroom in the back.
Jordan87
Re: 2+2+1 ish
Postby Jordan87 » Sat Jul 07, 2018 3:11 pm
Decided to pull it out to get some better shots and test the new hitch. ImageImageImageImageImageImageImage
Jordan87
Re: 2+2+1 ish
Postby Mr. Lahey » Sun Jul 08, 2018 8:02 am
WOW!! I love outdoor shots behind tow car. :applause:
Really gives good perspective to the size of the camper. Absolutely love that wide yet low look it has.
Keep at it. It's going to be a beauty.
My teardrop camper build journal: viewtopic.php?f=50&t=64721
My tool box teardrop build journal: viewtopic.php?f=50&t=70817
Mr. Lahey
Re: 2+2+1 ish
Postby danlott » Tue Jul 10, 2018 12:11 am
Jordan87 wrote:Decided to pull it out to get some better shots and test the new hitch. Image
Looking good.
Dan
Hoplite Traveler Build thread
danlott
Images: 258
Re: 2+2+1 ish
Postby Jordan87 » Mon Jul 16, 2018 8:04 pm
Some more done Sunday and finished up today. ImageImageImageImageImage
Jordan87
Re: 2+2+1 ish
Postby Wolfgang92025 » Mon Jul 16, 2018 9:24 pm
love the profile...... :thumbsup: :applause:
getting closer step by step. :D
Wolfgang
Wolfgang92025
Images: 482
Re: 2+2+1 ish
Postby Jordan87 » Mon Jul 16, 2018 9:33 pm
Thanks. Never would I have ever imagined it would be so rewarding yet so difficult haha!
Jordan87
Re: 2+2+1 ish
Postby Jordan87 » Sat Jul 21, 2018 9:43 am
So I'm a little hung up on door handles. I really don't want to spend a lot on prefab rv door handles. Does anyone have any recommendations? I saw an interesting idea using locking t handles but am not sure about the latching mechanism.
Jordan87
Re: 2+2+1 ish
Postby Jordan87 » Mon Aug 20, 2018 7:26 am
Been awhile but here are some updates. Doors done. Window testing. And forgot but hatch skin is on too.ImageImageImageImageImage
Jordan87
Re: 2+2+1 ish
Postby ojgrsoi » Mon Aug 20, 2018 7:44 am
Nice!!
Mark
Weatherford - True Texas
https://youtu.be/BKs6XfgAKKc
ojgrsoi
