50 HR. Build 4.5 by 8' using Railtop fiberglass Components
Postby saywhatthat » Fri Aug 03, 2018 5:34 pm
I finish a small trailer making my own fiberglass parts. Two years to finish. So now will buy and see how that go's .Will be doing 3 pods. So 50 Hr. each .Well see! This will be all fiberglass over foam. Woody have been built in under 28 hr. of work time. Home depot cut all the wood. Two working on them dad and 12 year old girl. 155223 155603
Il suffit de le faire
D.I.Y Light weight sleeper using D.I.Y rail top components.
viewtopic.php?f=50&t=66751
saywhatthat
Images: 139
Re: 50 HR. Build 4.5 by 8' using Railtop fiberglass Componen
Postby saywhatthat » Mon Aug 13, 2018 3:13 pm
I should have been clearer. Plan to build in under 50 hrs. This from of building uses a fiberglass skeleton frame. No wood .When using wood at some point you will have to glue, nail are screw into the end grain. Then add an alum. Cap that has memory and try to return back flat. It will be puling at any fasters that may being used. Wood get wet just from the water in the air. When it gets cold. In the picture the new outer ring .Was cut and laid up in 4hr and 12 minutes. For the left and right side. Used two envelopes and a cutting stick. DO NOT USE BODY FILLER AS SOME HAVE SUJESTED WILL FALL OUT AT SOME POINT .This form of building with fiberglass has been around for over 70 years are more Not in the last few years as some have claimed .155752
155753
saywhatthat
Images: 139
Postby saywhatthat » Thu Jan 03, 2019 9:03 pm
Picture 401.jpg (187.08 KiB) Viewed 336 times
[attachment=0]back inside.jpg[/attachment ]I am sorry for not posting .As this way of building is fast you can not make a mistake . I had the side wall removed I hope they do something with them. So here some pictures As soon as door jam show up will do up date on new build. . Call your fiberglass shop see if they make some thing like this.
Picture 405.jpg (333.18 KiB) Viewed 336 times
back inside.jpg (440.43 KiB) Viewed 336 times
saywhatthat
Images: 139
Postby saywhatthat » Thu Jan 03, 2019 10:20 pm
Picture 416.jpg (118.75 KiB) Viewed 69 times
How fast a 2400mm long 1375 high under two hours over four days to do outer rings
À quelle vitesse une 2400 mm de long 1375 haut moins de deux heures sur une période de quatre jours à faire des bagues extérieures
saywhatthat
Images: 139
Postby saywhatthat » Fri Jan 25, 2019 10:57 pm
Picture 435.jpg (151.94 KiB) Viewed 134 times
Finley received my door jams. There designed to fit the frame profile. That way different accents can be added. They were designed for a 5 by 5 by 10 feet long off-road trailer with pop up roof. Sadly the side panels were removed stolen. Set the cash back some. So now building a 7 foot sleeper/weekender To make the doors fit will angle the top and bottom near the fenders. Cannot move the axle back 60 /40 rule. This way of building can be done with a few hours of work and last for a 100 years or more. If you plan to try this No big investment in tools $20.00 U.S . Cannot make a mistake .Should be able to have your local fiberglass shop modify a excising tooling. Received some hate .Not the one that is trying to get $35.00 a running foot. Cost should not be more than $10.00 a running foot
Finley a reçu mes embouteillages. Là conçu pour adapter le profil de cadre. De cette façon, différents accents peuvent être ajoutés. Ils ont été conçus pour une remorque tout-terrain de 5 x 5 x 10 pieds avec toit ouvrant. Malheureusement, les panneaux latéraux ont été volés. Définissez la remise en argent. Alors maintenant, construire un dormeur / weekender de 7 pieds
Pour adapter les portes va incliner le haut et le bas près des ailes. Impossible de reculer la règle des essieux 60/40. Cette façon de construire peut se faire en quelques heures et durer 100 ans ou plus.
Si vous envisagez d’essayer cela Pas d’investissement important dans les outils 20,00 $ US. Vous ne pouvez pas vous tromper. Vous devriez pouvoir demander à votre magasin de fibre de verre de modifier un outil d’excision. Reçu de la haine. Pas celui qui essaie d'obtenir 35,00 $ le pied en cours d'exécution. Le coût ne devrait pas dépasser 10,00 $ le pied
saywhatthat
Images: 139
Postby saywhatthat » Fri Feb 01, 2019 10:19 pm
Picture 439.jpg (81.38 KiB) Viewed 134 times
Had to trim the doors down. So thought was to cut corners .If was to do over .Would cut narrower and eat more rabbet food. As one corner is finished will pull a plaster of pairs tooling .
Picture 438.jpg (112.64 KiB) Viewed 134 times
Will make the last three corners so all will be the same .Then bond in . Two side doors
saywhatthat
Images: 139
Postby saywhatthat » Sat Feb 02, 2019 11:45 pm
Picture 441.jpg (152.54 KiB) Viewed 93 times
.Now I have the doors trimmed in the corners .Need this profile so could use back center spacer. Spacer is to build an 5 feet wide using 4 foot material on top. Now can have fiberglass on the bottom wood on top thinking 1/8 Cherry are ash striped planking. All fiberglass is hand laid NO chopper gun S****
Off-road plate bottom fiberglass on top
Picture 445.jpg (86.58 KiB) Viewed 93 times
Picture 446.jpg (97.71 KiB) Viewed 93 times
saywhatthat
Images: 139
