The Coddiwompler
Re: The Coddiwompler
Postby noseoil » Tue Nov 24, 2020 8:31 am
I used 4/4 poplar for the cross-spars, it's light, clean & straight when you cut it from a plank & it's plenty thick enough. Also, a few "prop" sticks & a sheet of 1/4" plywood will hold up a sag in the headliner until the glue sets. With the canvas applied to our birch headliner first, I needed to be careful of the glue & didn't want any fasteners to show when the ceiling was finished. With the side panels cut with a rabbet joint, it was fairly easy to lay the headliner in place with 2 people. Then, there's a lot of blocking to cut to set things in place for the insulation & outer skin.
Looks like it worked well enough for your build, there's always something...
137905
noseoil
Images: 669
Postby eLink » Sun Feb 28, 2021 9:09 pm
Slow going lately, but making progress...
Test fitting the bubble window with a scrap piece of Trimlok. I think it's gonna work out!
Started building the hatch!
eLink
Images: 142
Postby lfhoward » Sun Feb 28, 2021 9:17 pm
That hatch skeleton looks good! Nice progress.
lfhoward
Postby eLink » Sun Mar 21, 2021 2:49 pm
lfhoward wrote:That hatch skeleton looks good! Nice progress.
Thank you!
I got the interior side skinned this weekend. Next time, I'll trim most of the excess before gluing. I couldn't get a clamp around that wide lip so the process was a little more tedious than expected...
Lots of kneeling, applying pressure by hand and stapling. Little by little, but it worked out ok.
Edges trimmed. Oops, forgot to check my router depth for that hardware recess! Looks like cigarette burns.
...and that'll do for now!
eLink
Images: 142
Postby tony.latham » Sun Mar 21, 2021 3:31 pm
I had to put a couple of pocket screws in mine to hold it down while the glue set.
It was a bit of a rodeo. :frightened:
Postby eLink » Sun Mar 21, 2021 3:50 pm
tony.latham wrote:I had to put a couple of pocket screws in mine to hold it down while the glue set.
But that woulda' been too easy.
Honestly, I keep forgetting to review all the resources here, including your book and videos, beforehand!
eLink
Images: 142
Postby tony.latham » Sun Mar 21, 2021 5:57 pm
Honestly, I keep forgetting to review all the resources here...
I believe all the thinking-through during our builds is part of the satisfaction.
Postby Bezoar » Sun Mar 21, 2021 6:56 pm
Looking great! Please provide more info/photos on the bubble windows. Are they similar to the plastic things they make for dogs to look thru fences? I thought about those for my boys, but was chicken to try it fearing water intrusion!
Bezoar
Images: 37
Postby eLink » Mon Mar 22, 2021 10:20 am
Bezoar wrote:Looking great! Please provide more info/photos on the bubble windows. Are they similar to the plastic things they make for dogs to look thru fences?
Yes, they are similar. But I found a company that will make custom sizes, materials, tints and shapes.
https://www.eztopsworldwide.com/smalldomes.htm
On my non-insulated, 3/4" thick walls, the window openings are routed so that there is a 1/8" thick lip all around to receive the Trim-Lok gasket. The gasket I chose provides a double-seal against water intrusion. It's too early to tell whether they will be completely weatherproof. But I'm feeling confident about it.
eLink
Images: 142
Postby eLink » Sun Apr 11, 2021 11:31 am
I opted to insulated the hatch as added defense from the sun for my ice chest.
My hatch framing is 2" deep so I used two layers of 1" thick polyiso boards, which I managed to acquire for FREE!
Cutting and kerfing would have been a huge mess if not for my new cheapo automatic dust-collection system!
Peeling the foil off of the second layer allowed it to fit more snugly into the cavities.
It was a lot more work than anticipated, but still a good learning experience.
eLink
Images: 142
Postby eLink » Mon Apr 12, 2021 4:22 pm
Skin on, and the hatch keeps getting heavier!
eLink
Images: 142
Postby PitterPatter » Tue Apr 20, 2021 6:26 am
Thanks for this! Your build is inspiring (Coddiwompler!) and I enjoy following your thoughtful and well-documented journal. :thumbsup:
PitterPatter
Postby eLink » Wed Apr 21, 2021 4:55 pm
trailzy wrote:Thanks for this! Your build is inspiring (Coddiwompler!) and I enjoy following your thoughtful and well-documented journal. :thumbsup:
Glad you like it!
Got the bottom rear panel installed today. For a 6" radius bend, it definitely helped to pre-bend the plywood. I made use of an old picnic table to hold it in place while soaking and bending it for a couple of days.
164892 164891
Glued with PL Premium and stapled.
164893 164894
eLink
Images: 142
Postby eLink » Sat May 08, 2021 3:03 pm
There is a 1/4" gap on the sides of my cabinets which is meant as a wire chase. Turned out to be a real pain when it came to pulling the wire! I realized that it would be nearly impossible to fish wire once the roof is complete, so now is the time!
Really tight squeeze! Hopefully I won't need to add any more.
eLink
Images: 142
Skylight Openings
Postby eLink » Tue Jun 01, 2021 2:26 pm
I kept stressing about whether I really wanted a skylight or not. Whatever, I've come this far...might as well go for it!
Before: 165797 After: 165800
So long beautiful ceiling... It was nice knowing you!
Before: 165798 After: 165796
eLink
Images: 142
