The Dutch Oven Build
Postby Gruney416 » Wed Feb 13, 2019 11:37 am
Hello All,
I (Sarah) definitely did this out of order, but here it is... Our Teardrop, meet the Dutch Oven. (*insert childlike snickering*) I wanted to post our adventure building it last summer because I used so many of your build journals and advice to source the perfect products and materials to create our home on the road and hope that someone else will find some inspiration to do this themselves!
She is built out of a recycled 5x8 boat trailer that my Father-in-Law acquired and shortened the tongue for us, Plywood, and Fiberglass panels that we've UV treated with Marine Paint. I'll go through the step by step via the pictures we had, but thought I should introduce her first.
We started the build Memorial Day weekend 2018 with a trip to raid my FIL's garage and get the trailer, got her campable (barely) by June 21st, 2018 and finished completely by September 23, 2018 with most of July spent keeping cool and not in our garage. We're so proud of how she turned out she made our annual Christmas card!
Thank you for all the Inspiration & guidance as we worked through this journey!
-Sarah & Sean
157295
Gruney416
Images: 7
RE: our Little Dutch Oven
Postby Gruney416 » Wed Feb 13, 2019 9:37 pm
So we began the build with a standard boat trailer that my FIL found for us. He was able to remove most of the structure for winching and supporting a boat. Plus he shortened the toungue quite a bit to make a pretty standard 5'x8' trailer. It had lived a good life thus far and was covered in rust, stickers, and peeling paint.
157296
My husband took a grinder to the trailer once we got it home and in the garage to remove the extra brackets, paint, and rust to get a clean trailer that just needed a coat of paint. We also removed all the old wiring as most of the wire insulation was cracked and wires were corroding.
157299
We chose a gloss black rust-stop (likely good ole' Rustoleum) to coat the entire trailer to protect it.
157298
As for the structure of the Teardrop body itself, I had spent a great deal of time reading build journals, watching builds on YouTube, and using Pinterest to find ideas. I came across the plans from teardropbuilder.com and downloaded a copy of the Wyoming Woody plans. We used them as a guideline for the structure, and deviated fairly significantly. It is definitely not the same measurements or assembly as his plans, but we used his build journal as a guide as we assembled.
We did build a base similarly to his and many of yours. There are 4- 2x4's running the length of the trailer pretty close to 24" on center to help support the 4'x8' sheets (1.5 sheets per side) of 1/2" plywood which skins each side. We used leftover Fiberglass insulation from a home remodel to insulate between the sheets of plywood. Coating the entire box- top, sides, and bottom with rubber bed liner coating and silicone to weatherize & waterproof.
157300
The entire box is bolted directly from the bottom to the trailer frame. It is going nowhere.
Gruney416
Images: 7
