tony.latham wrote:I got a few things done...
The template is complete and stashed. Take a look and tell me what's wrong with this ...
You need to give us a virtual tour of your brand new (gravity defying) workshop one of these days.
tony.latham wrote:But the biggee was cutting the ceiling shelf from the skeletons. With my other builds, I had used a jigsaw. On this one, I used my plunge base and Rockler's router guide so it had my full attention.
I think it took me four passes per skeleton but they are nice and plumb. I'd choose this method again and it was a good warm-up for when I cut the hatch ends.
Tom&Shelly wrote:tony.latham wrote:But the biggee was cutting the ceiling shelf from the skeletons. With my other builds, I had used a jigsaw. On this one, I used my plunge base and Rockler's router guide so it had my full attention.
Nice! What is the bit diameter?
Will be curious to see the finish with your new coating system.
Tomterrific wrote:I think I got this tip from Harold Payson. When using resin and fiberglass tape to strengthen a joint, cut the tape on a bias. The fibers of the tape will both be across the joint instead of only one fiber. So obvious yet I never thought of it.
Great job Tony and really fine workmanship. I so admire folks who aren't a hack builder like myself.
Tt
swoody126 wrote:DUCKWORKS BBS sells the bias cut fiberglass tape by the yard or by the roll
https://www.duckworks.com/product-p/fib-biax-parent.htm
a BTW, i used2 use West System stuff exclusively but have been using DuckWorks recently w/ excellent service provided
the RAKA Epoxy they sell has a UV inhibitor & a BLUSH resistor in it as well as being considerably le$$ co$tly
and i personally feel it doesn't smell as strong as West System stuff does(butt i only use any of that type of products in WELL VENTILATED AREAS)
i have also started using their WOOD FLOUR as a filler as i'm using up my West fillers and unless i need the glass strand filler i'm thinking i'll stick w/ the flour for filing n fairing
Users browsing this forum: No registered users and 38 guests
