Another Offroad Teardrop
Postby trail_limo » Thu Jun 27, 2019 3:43 pm
I've been working on this for a while, but am just now catching up to posting about the build process. Building a 5x8 rugged teardrop to improve foul-weather camping for my wife and son. Here's the progress so far
Building the frame out of 2x2 1/8" thick steel
Getting closer
On her own weight!
Got fenders framed
Frame done with a couple coats of primer
Couple coats of paint
Got the floor on
Walls up, everything is 3/4" baltic birch. 5'x10' sheets
Galley coming together! Bulkheads were fit together with dado joints. What a pain it was fitting the walls down between the fenders.
Started on the roof spars which are 1x2s glued together
Some interior cabinets
Ran the electrical for the running and clearance lights through the frame
Starting the insulation and roof underlayment
That's it for now! I've been working on it since September 2018, shooting for completion by the end of Summer 2019.
trail_limo
Re: Another Offroad Teardrop
Postby scoopburt » Thu Jun 27, 2019 6:02 pm
Very nice. What are you planning for the final exterior coating? PMF, Fiberglass/epoxy, Raptor liner?
Thanks for sharing
scoopburt
Postby Sparksalot » Fri Jun 28, 2019 11:38 am
What are you planning for the hitch?
Sparksalot
Images: 682
Postby trail_limo » Mon Jul 01, 2019 12:30 pm
scoopburt wrote:Very nice. What are you planning for the final exterior coating? PMF, Fiberglass/epoxy, Raptor liner?
Thanks for sharing
I have 4 sheets of 5'x10' aluminum that I'm going to finish it with. It's 5052, .040" thickness. Also planning to use "the mix" on the entire thing before skinning with aluminum.
trail_limo
Postby trail_limo » Mon Jul 01, 2019 12:32 pm
Sparksalot wrote:What are you planning for the hitch?
I'll be using a max coupler on an extendable tongue that can extend/retract about 36"
trail_limo
Postby trail_limo » Mon Jul 01, 2019 12:35 pm
Got the roof underlayment finished yesterday!
Also got more of the galley cabinetry framing done
trail_limo
