Australian Off Road Teardrop Build
Postby Daz7 » Thu Nov 07, 2019 3:17 am
I've been reading this forum for years and decided it was time to start building this Teardrop I've always promised myself.
So through the ex military auctions I purchased a No.5 Australian Army Trailer. Actually after buying 1 for the build I liked the trailer so much I've also purchased another as a general use box trailer also.
Daz7
Re: Australian Off Road Teardrop Build
Postby Daz7 » Thu Nov 07, 2019 3:19 am
Then through the process fo getting the trailer registered before tearing it down.
Daz7
Postby Daz7 » Thu Nov 07, 2019 3:20 am
Finally got into removing the tub and weighing the chassis.
Daz7
Postby Daz7 » Thu Nov 07, 2019 3:22 am
Prepped the chassis, purchased new wheels and tires and measured up for a new braked axle
Daz7
Postby Daz7 » Thu Nov 07, 2019 3:23 am
And finally, start to get some walls up, starting to look like a camper :D
Daz7
Postby Az Pete » Sat Nov 09, 2019 11:26 am
Looking good!
Az Pete
Postby GTS225 » Sat Nov 09, 2019 7:49 pm
I agree with Az Pete. Looks like you've got yourself a solid platform to build on.
I might suggest that you replace that rear pintle receiver with a standard square receiver, though. That way, you could plug in a cargo tray, if needed, or fabricate any manner of accessories as you see fit.
I did notice that the spring pack seems rather thick. What's the cargo capability of those trailers? You might need to take a leaf or two out to soften up the ride.
Just a couple observations on my part.
Roger
GTS225
Postby Daz7 » Sun Nov 10, 2019 12:41 am
Thanks for the comments. The payload on these is 500kg (1100lb) on top of the original trailer that weights 350kg (771lb) So 850kg (1870lb) all up.
Weighted where we are today and I'm at 429kg 945lb) with the empty fridge in the fridge slide frame.
Funny enough the standard trailer rides very well empty so I think the leaves look at lot worse than they really are. That said see how it goes as we progress.
This weekends progress.....
Daz7
Postby tony.latham » Sun Nov 10, 2019 11:18 am
Great job thinking through the headliner slots.
Postby Daz7 » Sun Nov 10, 2019 9:40 pm
Video of the weekends trailer build outcomes.
Daz7
Postby Daz7 » Sun Nov 17, 2019 10:19 pm
Slow weekend doing a cupboard, still some tweaks to go but its roughly installed and looks the goods.
Daz7
Postby Daz7 » Wed Nov 27, 2019 5:27 am
latest build updates
Daz7
Postby Daz7 » Tue Dec 03, 2019 10:24 pm
Latest update - Mudguards and more
Daz7
Postby noseoil » Fri Dec 06, 2019 9:22 am
Looking very good, I like the simplicity & thought process you have for assembly, light, strong & simple works very well on a build.
The finish work is what takes the most time, cabinets & interior detailing will eat up more time than the cabin itself, but it's worth the effort. Really enjoying the build videos, keep up the good work! Want to see it rolling when it's finished.
137905
noseoil
Images: 540
Postby Daz7 » Fri Dec 06, 2019 10:04 pm
Thanks so much, I'm enjoying this build a lot should have done it sooner.
Daz7
Users browsing this forum: hossesdad and 9 guests
