Thank you Jansen. Possibly. Not sure yet. Wheels are still turning.JasenC wrote:It's looking great.
For the rear are you just planning some type of roll pan like a pick up w/o a bumper?
Thank you Tony.tony.latham wrote:A really really fine job.
I really like the laminate planks. Just about any of them out there will do. I chose the middle of the road price wise of planks, just because of the small area I was going to cover. I floated them just like you do in a home. I ended up putting quarter round over them as well, but you almost never see them because of the mattress. I also put planks in the galley and they seem to be holding up nicely even in the weather. I would recommend and would do the planks again. And thank you for the compliment!dabend wrote:How do you like the laminate flooring planks that you used? I tried self-stick vinyl planks because I thought they would be durable and easy to clean, but was sadly disappointed in how the edges keep popping up even though I smoothed and sealed the floor before putting them down. I plan to replace them next year and the laminate planks look like a good choice. Did you glue them on or are they floating?
You have a nice looking camper and I like how you made it oversize on the 5x8 trailer! Darrin.
KCStudly wrote:I had the same issue with self adhesive tiles curling up on a work bench/countertop. I went ahead and reglued them down with the same adhesive, and notched trowel, used for non-self adhesive tiles; never had a problem again.
Great suggestion! Now I won’t have to figure that out the hard way! Thank you!Tom&Shelly wrote:Looks good!
We found with ours, the AC eventually froze up when we had the return air coming from the cabin. Fix was simple: simply leave off the return hose and get the air from outside.
For heat, we need that return!
