Luke's 6x12 Cargo Conversion
Postby Lrogers1843 » Mon Dec 20, 2021 9:40 pm
Hey all! I've been poking around here for a few weeks since the idea for a DIY camper popped into my head. I cycled through a few ideas, including a full foamie build, before settling on a 6x12 cargo trailer conversion.
Why build a camper at all? This project arises for me out of a lifestyle change - I'll be working as a wilderness guide for weeks at a time next year, and I have a home base with showers and kitchen where I can leave a camper, but without this I would just be living out of my car. Hence the urge for an upgrade! I will luckily have good lounge space to spend time in at this river base facility where I'll be parked, but also wanted to make a little private retreat room for myself out of the public fray. Plus, I'd love to make it as off-grid ready as possible for unforseen adventures, and because I am a solar enthusiast in general.
Unfortunately, I have almost no experience with the basic building skills that are needed here, besides a little bit of ugly shelf construction. Oh, and I don't have much time. I want to be road ready on March 1, just a bit over 8 weeks out. Please wish me luck and please chime in if you see any big mistakes looming!!
The trailer, purchased new in Douglas, Georgia
167836
nose design sketch
167837
rear design sketch
167838
I'm still playing around with the final window count and placement - hoping to nail that down very shortly to order them. One hangup is also the wall thickness - I plan to land at about 1-3/4 total, with 1" metal wall studs inside the aluminum skin, adding 1/2" foam on top of that (in addition to between the studs), then then plywood interior that I'll just paint. Deliberating whether it's best to cut down a 2" wall thickness trim ring or just live with the small gap from 1-1/2 trim ring....
The next few days will focus on removing the existing plywood walls and forming a floor insulation and sealing plan - had intended to add furring strips and 1/2" foam + 1/2 ply on top of that, but recently saw a post building out the sandwich from below, which is attractive to save head height. Will keep exploring!
Lrogers1843
Images: 15
Re: Luke's 6x12 Cargo Conversion
Postby Lrogers1843 » Tue Dec 21, 2021 12:09 pm
Started today with a weigh-in, including all stock interior plywood panels
167839
Then I did an undercarriage inspection - the crossmembers are pretty deep and it seems like foam could be pretty sheltered between them, so I think I'll go with this approach for floor insulation.
The plan:
- Another waterproofing paint layer on the exposed plywood floor
- Loctite® PL® 300 Foamboard adhesive to attach foam
- More waterproofing paint over the installed foam
Any red flags with paint/adhesive compatibility here? I would have loved to epoxy the wood and glue the foam to that, but I'm not sure it makes sense without getting the factory paint off, which feels like overkill for my time constraints.
167840
Lrogers1843
Images: 15
Postby Lrogers1843 » Tue Dec 21, 2021 8:16 pm
Today was spend mostly pulling out the interior plywood (not easy!) It is especially tricky around the side door trim, think I'll come back with a jigsaw to cut closer to those edges and get a little more room to work.
before
167841
after
167842
The next insulation challenge I've encountered is the doors - I think I'm too nervous and too rushed to take them apart and insulate inside. I'll need to think about how this would sit relative to the rest of the interior walls, but I'm tempted to simply glue foamboard on them and paint it white to match my walls. This feels especially appealing on the barn doors, which will be relatively low traffic and low visibility. Maybe with a PMF finish (I almost tried a foamie build, would be fun to do a bit of that technique)
167843
Lrogers1843
Images: 15
Postby Lrogers1843 » Sun Dec 26, 2021 7:33 pm
Turning attention to weatherproofing while I have the interior exposed. I see two types of issues to address:
1) Floor gaps where the footprint makes turns off 90 degrees.I think I may attack this from below, using adhesive to attach a thin steel plate across the gap where the beams don't meet, then some spray foam or other filler on top.
167902
2) Sloppy existing penetrations - all purpose silicon applied from outside? This one inside the wheel well is particularly disappointing.
167901
(thank you, Diamond Cargo)
Lrogers1843
Images: 15
Postby Lrogers1843 » Sat Jan 01, 2022 10:27 pm
Minor progress: All of the vertical outside seams and especially the front failed the garden hose test, so I sealed them with clear silicon - looks ok from a distance and holding out water pretty well.
167964
meanwhile, major appliances have trickled in, including inverter/charger in back corner. I also have solar panels and am just waiting for my 5kWh server-rack battery to ship before trying all that out.
167966
I want to make major penetrations soon, starting with windows, which have now arrived. Plan is to cut steel studs and weld horizontal support angle iron to to attach the cut ends to neighbors, then trim the rest of the window hole out with dimensional lumber, I think.
plus, I thought out roof rack designs for the solar panels. The goal is to lay 3 of them inside an aluminum angle frame, all of which will pivot on a hinge to catch angled sunlight. The geometry didn't look good for my original plan of side-mounting the rack, so I think I'll switch to a roof-mount approach, although I hate to start cutting into the roof. Below is the rough sketch that convinced me to mount on top - approx weight of 3x250W solar panels and homemade aluminum frame is expected to be 125-150#.
167965
The roof seems multilayered, which I didn't expect - soft plastic-y layer exposed inside:
167968
and another layer on top, with aluminum panels in between? I'm a bit worried about potential flex or creasing of the top layer, and getting a good seal on it. Current plan is dicor self-leveling lap seal. Time for a deeper dive through the forum on roof openings in cargo trailers.
167967
Lrogers1843
Images: 15
