This teardrop was built by a guy that worked in the rv industry. I'm the second owner and it has had very little use. It can be hooked up to shore power, has a 12 volt battery, a built in battery charger, 110 volt outlets and a 12 volt accessory plug, 12 volt lights inside and out. It can be towed by a small car due to its low weight and low tongue weight. I move it by hand in the backyard when I mow the grass.
$2300
CALL STEVE 765-565-6817
