removing paint from appliances
Canned Hams of all types and sizes...and Bread Boxes to go with that ham......
Postby elad » Sun Jan 23, 2011 8:27 am
So the first thing I noticed in my new Aladdin is that the last owner had painted over the aqua stove top and icebox. He didn't like the color.
Is there a way I can safely remove the paint while leaving the original?
Thanks!
Dale
elad
Postby WhitneyK » Sun Jan 23, 2011 9:35 am
If your lucky the previous owner used latex which can be removed (hopefully) with regular household ammonia. Ammonia works like paint thinner does on oil base or enamel paint, it's a "carrier". If it's enamel paint, you might go at it with stripper or laquer thinner?, just don't let it set long. Maybe even use it on a rag and rub it in (like waxing), then wipe clean when you start to see the green show through to stop the desolving process. Maybe even use a wet rag to nuetralize the stripper/thinner.
If you try these, do it in an inconspicuous spot so if it does take of the alvocado green, it won't show.
Just a thought, didn't say it was a good one!
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
Re: removing paint from appliances
Postby cooterdude » Mon Mar 04, 2013 10:25 pm
ive had good results with a product called citristrip its orange based so it shouldn't hurt the enamel surface under the paint your trying to remove
cooterdude
Return to Canned Hams & Bread Loaves
