RV tank and Toilet
RV tank and Toilet
Postby RetchedOne » Sat May 09, 2015 7:35 pm
I'm doing a Cargo Conversion, and have 2 40 gallon tanks below, one grey, one black. The black will be directly below the toilet, with just a 3/4 ply floor separating the tank top and toilet floor. I'm using a standard RV toilet.
How does the toilet attach to a black tank? I see fittings that look like I cut a 3.5 inch hole, and they pop in place and get sealed... then what???? Can anyone provide links to what I need?
Thanks all!
RetchedOne
Images: 9
Re: RV tank and Toilet
Postby MtnDon » Sat May 09, 2015 8:13 pm
That's about it. Hook up a fresh water line to flush, add a vent pipe and there ya go.
I guess I don't understand the question.
MtnDon
Images: 24
Postby RetchedOne » Sat May 09, 2015 8:14 pm
What fittings go between the bottom of the toilet to the tank?
RetchedOne
Images: 9
Postby RetchedOne » Sat May 09, 2015 9:42 pm
I'm looking at this toilet -
http://www.amazon.com/Dometic-302310071 ... ometic+310
Installation PDF -
http://www.factoryrvsurplus.com/files/D ... lation.pdf
I have this tank -
http://www.alphasystemsinc.com/files/ca ... 5-2012.pdf
I think this piece goes into the tank (directly below the toilet) ???
http://www.amazon.com/Custom-Roto-Moldi ... 263_text_y
And this piece bolts to the bottom of the toilet and slides into the piece above ???
http://www.amazon.com/Dometic-307345892 ... NB57C9TD43
I believe this is the seal kit
http://www.amazon.com/Dometic-385311652 ... +385311652
RetchedOne
Images: 9
Postby Iconfabul8 » Tue May 17, 2016 5:12 am
I believe your questions is, " how do you attach/glue/mount the toilet flange to the tank?" I too have been a little curious about this.
Maybe this: http://www.campingworld.com/shopping/it ... slip/68818
And this: http://www.campingworld.com/shopping/it ... ange/68820
Iconfabul8
Images: 14
Postby msnglinc » Mon May 23, 2016 8:11 pm
I too am interested in this. About to start the bathroom of my cargo conversion and need to gather parts.
7 x 26 Cargo Craft V Nose
viewtopic.php?f=42&t=63350
msnglinc
Postby Redneck Teepee » Mon May 23, 2016 8:37 pm
You will have to get from your tank connection on top to what is called a Herco Ring or closet flange. The blue ring at left in the picture is the herco ring, it's what you bolt your toilet to, it rotates so you can clock it any direction to orientate your toilet square with the room or whatever.
http://www.gumpydog.com/Bus/MC9_WIP/Plu ... bfloor.JPG
Redneck Teepee
Images: 21
Postby Tommy B » Tue May 24, 2016 2:00 pm
Retched, I am in a similar situation. If you check out my thread there are pictures of what you are describing. I used a 3 inch valtera floor flange which required a 4 in hole I BELEIVE. Much has passed sense I cut that hole But I could confirm if need be. My tank will be here this Friday and I plan on mounting it sat if all goes well. The flange fits tight and flush and passes through that 3/4 inch plywood with much thread to spare to screw into your tank fitting. It is a male 3 inch valtera floor flange. I have no idea how I will mount the tank and there is no easy button.
Cargo conversion thread. 6x12 hallmark thread will have better pic. I don't have time right now good luck.
Tommy B
Postby Tommy B » Tue May 24, 2016 2:01 pm
I have the dometic 310
Tommy B
Postby Tommy B » Tue May 24, 2016 3:04 pm
There you go retched.
Tommy B
