Well I didn't feel like fighting the crimper aymore (tool, supply, operator error, or ALL OF THE ABOVE)
I did some research and found that the cinch ring method was more preferred by local plumbers. So I invested in the tool, and got it all done. No leaks !!
Now I can move on to more fun stuff. I've got to finish framing up the front cabinets/counters.
Then mount the shower, after drilling the hole in the floor, then mark, drill and glue/weld fittings on to the grey water tank for shower and kitchen sink to drain into.
Then FRP the shower walls, then make the cabinet-box for the frig to sit on. then get it installed, then run propane lines from front tank rack to stove, water heater, furnace...
All by the weekend of 2-14-13.. This should be fun and fast paced..
