The body of the lockers were shaped using a cheap workbench as a makeshift brake. Actually there is a detailed breakdown of how I built them here: http://www.tnttt.com/viewtopic.php?f=54&t=47079.
Later taters,
Dr. C-Dawg
CarlLaFong wrote:^^^^^^I don't think so.
The pressure relief valve is designed to open when the pressure becomes excessive. Once the pressure returns to normal, the valve resets. Someone didn't tighten the shut off valve and your gas leaked out. I had the valves pop on both of my tanks, in our fifth wheel, in Phoenix, in July. 120F that day. They blew propane for 5 minutes or so and then all was good. No, I would never toss them in the trunk of a car and leave them there. I think if you can't mount them on the tongue or a dedicated compartment that is open to the pavement, you should leave them at home. If you're a home builder and you don't have room for it, then that's just poor planning
