a new one
Re: a new one
Postby fm-usa » Sat Mar 16, 2013 4:59 am
ANOTHER good read, at least it's not a WASTE of time.
:R
Commode camaraderie, a place to gather of similar interest butt not all at the same time and the pit of discussions usually aren't very deep.
(drum) DUH-duh DUMP
I had thought of a raiseable tank that after it's filled using a hand or elec pump would then be a normal gravity system.
And if that tank gets rancid or broke, it's very easily replaceable.
Pipes under the trailer is a really great idea and holds the weight at or possibly below the axles. Since my trailer will be towed behind a bike the smaller tanks minimizes the slosh factor.
Is it possible, FULL RV in a 48 Sq.Ft. footprint & stay under 500Lbs wet?
SHE thinks teardrops are "cute" but I prefer a SKOSH mo-room & at 65+ the
body doesn't react/extract/move/mend/bend/lend or work like it use'ta.
NOW! Those unwanted guests moving in, Mr. 'Arther I. Tus' & Ms. DVT (grrr)
fm-usa
Location: ILLinois_60085 ================= Floyd_&_Debbie_+_Bailey
Re: a new one
Postby Rlowell » Tue Dec 23, 2014 6:40 pm
This area of discussion is just a little Gray. We need a little more fluid conversation.
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Re: a new one
Postby fm-usa » Tue Dec 23, 2014 9:42 pm
That's a SOLID if I ever saw one.
:thinking:
fm-usa
Re: a new one
Postby Rlowell » Wed Dec 24, 2014 10:46 am
you are correct...there is no waste here. Great subject matter for those wanting to add water to their builds.
Rod :applause: :D
Rlowell
Images: 42
Re: a new one
Postby dales133 » Wed Dec 24, 2014 8:03 pm
I got a second hand steamer unit to transform into a smoker.bonus is the waste tank is stainless and make a perfect Grey water tank to match my 90 liter water tank
dales133
Re: a new one
I'll post some pics later
dales133
Re: a new one
Postby fm-usa » Wed Dec 24, 2014 10:02 pm
dales133 wrote:I got a second hand steamer unit to transform into a smoker.bonus is the waste tank is stainless and make a perfect Grey water tank to match my 90 liter water tank
I hope you never cross the lines.
:roll:
fm-usa
Re: a new one
Postby flboy » Fri Feb 26, 2016 8:18 pm
I asked the question here:
viewtopic.php?f=54&t=65497 .
Maybe I should have asked it on this thread. I did a search on the forum for "trapless" and didn't see anything.
Any comments on the question? Thanks.
Don (Flboy)
YouTube Video of Finished 7*18 with 2ft V-nose Trailer:
https://youtu.be/MUcMM86LA2g
flboy
Images: 376
Re: a new one
Postby fm-usa » Fri Feb 26, 2016 8:58 pm
flboy wrote:I asked the question here:
IF it were me I'd be looking at initial cost, replacement ease, simple near unbreakable design, EZ cleaning, parts found anywhere. NO rubber parts to replace, all metal to metal seal.
Drain directly to holding tank using no trap.
IF i remember it's about 3 inches from lowest connection to finish surface. Problem there is tightening the 1-1/2" nut.
No problem if the drain pipe goes into the side of the tank.
ALWAYS trade-offs.
MAYBE this kitchen drain?
fm-usa
Re: a new one
Postby flboy » Fri Feb 26, 2016 9:02 pm
That is an idea! I'd have to open each time I took a shower, but that would stop anything from bubbling up when not in use.
Don (Flboy)
flboy
Images: 376
Re: a new one
Postby Kaz » Fri Feb 26, 2016 9:11 pm
hope this wipes away the confusion.
Kaz
Kaz
Images: 122
Re: a new one
Postby fm-usa » Fri Feb 26, 2016 9:36 pm
flboy wrote:That is an idea! I'd have to open each time I took a shower, but that would stop anything from bubbling up when not in use.
I added some new info in the original post.
Problem with a P-TRAP is while traveling the water in the trap sloshes around and usually down thereby loosing that seal.
El-Stinko :?
fm-usa
A check valve question?
Postby Camp Wags » Mon Jun 27, 2016 2:39 pm
When and where will a check valve be needed? :thinking: My build will have both a tank with 12v pump and hook up for pressurized camp ground water. Will I needed a check valve on both systems or just on the 12v pump side to keep the pressurized water from back-flowing into the pump and tank? :roll: :?
Thanks Guys,
Gary
Camp Wags
Images: 57
Re: A check valve question?
Postby Iconfabul8 » Sun Jul 03, 2016 1:13 am
Camp Wags wrote:When and where will a check valve be needed? :thinking: My build will have both a tank with 12v pump and hook up for pressurized camp ground water. Will I needed a check valve on both systems or just on the 12v pump side to keep the pressurized water from back-flowing into the pump and tank? :roll: :?
Thanks Guys,
Gary
There is a check valve built into most pumps and inlet devices. The links below are examples that state that they have built in check valves. Just make sure the pressurized water is hooked into the system on the output side of the pump.
http://www.ebay.com/itm/350556870782?_t ... EBIDX%3AIT
http://www.ebay.com/itm/New-SHURflo-12V ... uG&vxp=mtr
Iconfabul8
Images: 14
check valve
Postby Camp Wags » Sun Jul 03, 2016 7:50 am
Iconfabul8,
Thanks for your reply. I have both of the items you linked to, so I guess I will not need any check valves.
Thanks,
:beer:
Gary
Camp Wags
Images: 57
