eamarquardt wrote: If you provide me with the specs for your frame I can have #1 son, with the $100K ME degree that I paid for, run some calculations to tell you how little you've effected the strength of the beam.
bdosborn wrote:eamarquardt wrote: If you provide me with the specs for your frame I can have #1 son, with the $100K ME degree that I paid for, run some calculations to tell you how little you've effected the strength of the beam.
I'd be interested in seeing that. Intuitively I would guess that a hole in the side would weaken it more than the top but I didn't spend that much on my degree.
P.S. Why not replace just the portion of pipe below the axle with flexible tubing?
bdosborn wrote:I didn't spend that much on my degree.
Hose Linky
bdosborn wrote:Intuitively I would guess that a hole in the side would weaken it more than the top.......lol:
