Bbq
Bbq
Postby droid_ca » Mon Nov 05, 2012 9:39 am
Does anybody use a Bbq instead of a stove in their trailer as I can't seem to find a stove and was thinking a Bbq might work
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Re: Bbq
Postby 48Rob » Mon Nov 05, 2012 1:16 pm
If you want to get dead quick, a BBQ with charcoal inside the trailer will do it...
A gas BBQ is safer, but isn't designed for zero, or very tight clearances=fire.
There are plenty of new and used safe propane stoves on E bay, craigslist, and at dealers, just do a general Internet search.
http://bc.kijiji.ca/c-cars-vehicles-RVs ... Z416681078
http://www.canadianlisted.com/propane+s ... g?start=40
Rob
48Rob
Re: Bbq
Postby bobhenry » Mon Nov 05, 2012 1:27 pm
My Smokey Joe Junior goes with us almost every outing. You can broil grill and even boil on it . Remove the 2 wire racks and drop in a 12" dutch oven and you have a table top dutch oven stand with built in wind break . Now have your oven as well.
As Rob says Use in a well ventilated area. Carbon Monoxide Kills !
Images: 2617
Re: Bbq
Postby asianflava » Mon Nov 05, 2012 2:30 pm
I've brought my BGE, but it's heavy and fragile. If I could get a smaller one it'd ideal.
asianflava
Re: Bbq
Postby droid_ca » Mon Nov 05, 2012 4:11 pm
I usually go to Ebay but thought that I'd like to actually see the stove or burner that I'm going to buy and I live in a 1 horse town the nearest town is about 3 hours away but we do have a home hardware here and they had Bbq's so I thought maybe that could work but I'd rather not wake up dead
“Fide Canem”
droid_ca
Images: 176
Re: Bbq
Postby NightCap » Mon Nov 05, 2012 4:37 pm
I use a bbq that looks like a tool box. Small, but big enough to cook a flank steak for a potluck. I got it at camping world.
It looked like this:
http://www.discountfleetsupply.com/umi123000.html
I bought the gas one but it stopped working so I turned it into the charcoal one. Which is much less money. Works good.
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Re: Bbq
Postby 48Rob » Mon Nov 05, 2012 7:23 pm
Of course not :R
A BBQ is great for cooking outside, but as you asked about one inside, it had to be mentioned...
The gas side burner on propane grills could be adapted to work, but an inexpensive one or two burner propane stove can be had pretty cheap, and has already been designed and tested to be safe for indoor use.
If you just have to put your hands on one first, maybe if you plan a vacation to attend a teardrop gathering you can see many options, it may also help you decide just what it is you want to build.
Of course there is always the danger of information overload...
Sometimes more choices aren't as good as there just isn't any realistic way to incorporate all the neat ideas out there into one trailer...
Rob
48Rob
Re: Bbq
Postby Greg M » Mon Nov 05, 2012 7:33 pm
I use a Coleman grill stove. It's propane, has a mid sized grill and a single burner for a pot, etc. I've also got the optional griddle for it. It will fit on my countertop, but I usually use it on a table. Picked it up on sale at Canadian Tire.
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Re: Bbq
Postby Shadow Catcher » Mon Nov 05, 2012 7:34 pm
We have both a three burner SS cook top and a small gas BBQ. The gas grill has 8' hose that plugs into a Bullfrog gas point in the rear of CR. A gas grill would be difficult to control (fine heat adjustment) and wasteful of propane. There are any number of gas portable one or two burner stoves all of which can be plumbed to work from a larger propane tank.
We used the grill a number of times on our trip west once for shiskabobs (meal on a stick) and the other times for steaks. One of the tasks for next year is finding a grill bag.
Re: Bbq
Postby bdosborn » Mon Nov 05, 2012 9:26 pm
Our grill rides on the tongue.
Swings out for use and is hooked up to the propane tank:
Swings bask in for transit:
Had one mounted on the teardrop too:
Images: 777
Re: Bbq
Postby bdosborn » Mon Nov 05, 2012 9:44 pm
asianflava wrote:I've brought my BGE, but it's heavy and fragile. If I could get a smaller one it'd ideal.
Boy that was good barbeque!
Images: 777
Re: Bbq
Postby droid_ca » Tue Nov 06, 2012 10:21 am
bdosborn wrote:Our grill rides on the tongue.
A little off topic but Bruce what did you use for your shovel mount on there looks like a nice clean set up you have
“Fide Canem”
droid_ca
Images: 176
Re: Bbq
Postby eamarquardt » Tue Nov 06, 2012 11:18 am
I had one of those on our boat. The thin SS mesh would rot away. We used to BBQ in thirty knot winds though, ha.
Gus
eamarquardt
Images: 150
Re: Bbq
Postby bdosborn » Tue Nov 06, 2012 1:49 pm
droid_ca wrote:A little off topic but Bruce what did you use for your shovel mount on there looks like a nice clean set up you have
Quick Fist
P.S. I thought about what I was using the shovel for and moved it into the truck away from the food. :frightened:
Images: 777
Re: Bbq
Postby Greg M » Tue Nov 06, 2012 8:53 pm
Eeww!
Greg M
Images: 85
