zroadhouse wrote:Good call. Will just any plumber / heating / cooling person do? I was looking for RV and/or food truck shops who would understand the issues and conditions of a mobile install
- flexible hose from black pipe to regulator on bottle
MtnDon wrote:
From there iron pipe can be used down and under the chassis. A 90 degree elbow would let you run the iron pipe up through the wood floor. Use a rubber grommet to isolate the pipe from rubbing.
Dale M. wrote:
Simple to use.... You just put it on end of piping and pump a little air pressure into system (something as simple as bicycle pump will do) and put it at maybe 15psi and record the value and then let it go for 24-48 hours (or more) and if pressure stays constant you have tight system, if pressure drops you have leak....
Dale
MtnDon wrote:From there iron pipe can be used down and under the chassis. A 90 degree elbow would let you run the iron pipe up through the wood floor.
