RV fridge as freezer?
Postby CanuckShooter » Thu Dec 14, 2017 1:21 am
I've come onto a couple old campers and was wondering if I could use one of the fridges as usual...and use another as a freezer in the build I am planning? Do those Dometic RV type fridges get cold enough to use as a freezer?
CanuckShooter
Images: 123
Re: RV fridge as freezer?
Postby CanuckShooter » Sat Dec 16, 2017 1:39 pm
Did I ask in the wrong section??
CanuckShooter
Images: 123
Postby Esteban » Sat Dec 16, 2017 4:45 pm
Dometic CFX Fridge/Freezers are rated to cool down to a freezing -7F.
Steve - SLO, CA
Esteban
Images: 15
Postby bdosborn » Sat Dec 16, 2017 5:36 pm
CanuckShooter wrote:I've come onto a couple old campers and was wondering if I could use one of the fridges as usual...and use another as a freezer in the build I am planning? Do those Dometic RV type fridges get cold enough to use as a freezer?
Probably the luck of the draw with what ever fridge you get. Some of the old propane ones work really well and some don't. The one I had didn't even keep the refrigerator at a safe level, so I replaced it with a 12V Tundra fridge. It will reliably get down to freezing at the price of much higher electrical usage.
Images: 777
Postby MtnDon » Sat Dec 16, 2017 8:36 pm
No, not the std RV fridge.
MtnDon
Images: 24
Postby John61CT » Sat Dec 16, 2017 9:41 pm
Get the 12V only compressor type.
Engel is the best, but even much cheaper ones are fine, check out CL, look for sales.
John61CT
Postby CanuckShooter » Sat Dec 16, 2017 10:58 pm
That's too bad, could have saved myself some money. Thank you.
CanuckShooter
Images: 123
Postby CanuckShooter » Sat Dec 16, 2017 11:09 pm
Esteban wrote:Dometic CFX Fridge/Freezers are rated to cool down to a freezing -7F.
I've looked at that type here in Canada, and they are very expensive. I already bought a brand new 3 way fridge, but as we are almost always boon docking having more freezer capacity would be a bonus for us.
I found this type which would work when we are out hunting and no 110 is available.
https://bensdiscountsupply.com/unique-2 ... 2-sm-grey/
The more I look, the more a small electric freezer and a small generator may be the way to go.
CanuckShooter
Images: 123
Postby Esteban » Sun Dec 17, 2017 3:58 am
truckfridge.com or northernfridge.ca sell fridge/freezers that may meet your needs more affordably.
Steve - SLO, CA
Esteban
Images: 15
Postby John61CT » Sun Dec 17, 2017 9:59 am
3-way fridges are for powered campsites, the 12V side is only for use while driving, too horribly inefficient for use off batteries.
John61CT
Postby Esteban » Sun Dec 17, 2017 3:29 pm
John61CT wrote:3-way fridges are for powered campsites, the 12V side is only for use while driving, too horribly inefficient for use off batteries.
:thumbsup: Solar power, stored in a battery to use when needed, can be sufficient to power an AC/DC fridge/freezer.
My teardrop will have a 160 watt 12 volt solar panel installed on the roof, a mppt solar charger, a group 31 AGM battery, and an AC/DC fridge/freezer. Most likely I'll buy a Dometic CFX-50US CoolFreeze or a Domeic CFX-40US CoolFreeze. The teardrop will also have a 30 amp shore power inlet, a PD4045 power center, all LED lighting, and a 7-way trailer connector so the tow vehicle can provide DC power to charge the teardrop's battery while driving.
It's kind of a belt and suspenders electrical set-up that should work under almost any foreseeable conditions, other than a Zombie Apocalypse.
:thumbdown: I do not plan to use or buy a generator.
Steve - SLO, CA
Esteban
Images: 15
Postby MtnDon » Sun Dec 17, 2017 7:01 pm
We have the 4.something cu ft truckfridge. Works well.
MtnDon
Images: 24
Postby MtnDon » Sun Dec 17, 2017 7:03 pm
The last full size RV we had with a Norcold 3 way used 10 amps when the fridge ran on 12 VDC.
MtnDon
Images: 24
Postby CanuckShooter » Sun Dec 17, 2017 10:10 pm
I use propane on extended hunting trips, and the 12v while travelling, the 110 is for when we have the camper unit parked in the driveway prior to heading out.
CanuckShooter
Images: 123
Postby John61CT » Sun Dec 17, 2017 11:34 pm
MtnDon wrote:The last full size RV we had with a Norcold 3 way used 10 amps when the fridge ran on 12 VDC.
yes that's huge for solar, an efficient compressor type uses a small fraction of that even when set as a freezer in sweltering conditions.
John61CT
