Has anyone ever tried coroplast under canvas? I was just wondering if coroplast would work as a hard edge under canvas for a foamie, or if the heat and adhesion problems would overwhelm the benefits...
GuitarPhotog wrote:Hi-temp hot glue works on coroplast, but little else. When I made a "trunk" for my recumbent bike, I sewed the coroplast together with nylon wire ties and covered seams with vinyl tape. PVA adhesives like Titebond will not stick to coroplast.
<Chas>
Q: Is it possible to paint on Coroplast?
A: Krylon Fusion® Spray Paint for Plastics will provide a thin durable layer. Follow the manufactures directions for application of the spray paint. Brushes and rollers are not recommended for direct application of paints to Coroplast because the paint layer is too thick and can easily peel and delaminate. For art projects you may use brushed application of compatible paints on top of the "primer"/ base layer of the Krylon Fusion® Spray Paint for Plastics.
Dry to touch:
15 minutes
Dry to handle:
1 hour
Net Weight:
12 oz.
Recoat Window:
Before 24 hours or after 7 days
Coverage:
Up to 25 square feet on a non-porous surface
Application Conditions:
50 to 90 degrees; and humidity below 85%
Clean up:
Mineral spirits
