I bought a heat gun and have experimented with bending foam. One thing that I noticed was I don't have enough hands to bend foam and hold heat guns.
Here is an idea to possibly achieve more controlled bends of larger sheets. A board acting as a foot pedal depresses an attached bending board that deforms the heated foam lying below it. The maximum deformation of the foam is limited by the spacing(
D) of additional boards lying on either side of the line beneath the bending board.
Here is the realized bender. Note: I added bungee cords between the table and the foot pressure bar to return the bending board to an elevation sufficient to allow travel of the foam to the next spot to be bent.
The foam here is only 0.75" thick. So far I have only tried bending small pieces of scrap foam. I won't try anything larger until Spring since I need to give back the garage to the car until then. I feel confident this will work with 1" foam. 2" foam might be difficult. I am not sure how much more difficult wider pieces will be to bend. I suspect using more aluminum foil to direct air flow and retain heat might be useful.
- foambender2.jpg (129.09 KiB) Viewed 1906 times
I, for one, would like to hear what other folks are doing with bending foam.
