I didn't get as much as I wanted done. I also didn't get many pictures.
I did get some sanding done taking glue lumps off.
I can't find my scissors for cutting my bias tube.
I did get some more foam cutters shaped. So when the time comes i can just move the solder gun from one to the next. It is becoming a nice little collection of tools.
I was going to install my fenders. Or at least fit them so that when the time came to do the final install it would be fast. (I don't want them permanently mounted til I am done wrapping the canvas around the bottom board. But I ran into the fact they fit fine before insulating the bottom of the floor but not after
, because I needed that 1" of height. Then it occurred to me I had just made awesome hot foam cutting tools. So I've added that to my agenda. (I might make a custom one for that purpose that takes out a wider slightly deper swath and is closer to the edge of the wood block so I can get right up against things and leave less to chip out by hand.
) Use the hot wire tools to cut insulation out of the bottom of the trailer to leave room for the fenders. A smart person would have just not glued foam in those spots or would have cut out for them first.
