GPW wrote:Heat the foam to 190 F and you can tie it in a knot ... We’ve really not begun to investigate bending thicker sheets of foam with Heat ... BUT (the qualifier) , we Have bent the heck out of 1/4” -1/2” ” foam for RC planes ... Just need to bend/heat on a bigger scale for a Foamie’ Camper ... 190F is not a difficult figure to heat to ...
skyl4rk wrote:So if one were to Titebond III glue kraft paper to the outside and let it dry, then try to bend it with a ratchet strap, you could get more bend out of it?
