stamati wrote:Amazon sells a 100w flexible solar panel by HQST. It fits flush on it's mounting surface, can be attached with high strength velcro and weighs only four pounds.
GPW wrote:We believe somewhere was written that Heat causes a loss of efficiency in solar panels too ... A small frame of some type , to let air circulate behind it may help ..... a “chimney” sort of thing would be even better ... creating a steady FLOW of air , cooling the panel ...
Just looking around Amazon , looks like Solar prices have dropped to a much more reasonable level ... < $1.50 a watt ...
Move over Big Oil, there’s a Big Hydrogen fire in the sky willing to feed us power for Billions of years ... All we have to do is capture it ....
GPW wrote:JMHO, I doubt it would melt a foam roof .... not in the Sun anyway ... Even with black painted canvas over foam , it never even got hot enough to soften the foam ... That’s been tested !!!
Bonnie , with 12 Volt Deep discharge batteries (Not regular car batteries) you can just keep adding them in parallel +to+ , - to - , as much as you want to increase the CAPACITY , the storage ...
ghcoe wrote:Lots of good info here. Listen to the podcast too. http://solar1234.com/
