lthomas987 wrote:This is what I did and was trying to describe earlier. After the wall was glued up and dry I unscrewed the offcuts and reversed them. I did run drywall screws both into my wall foam and into my floor. But I wasn't worried because I hadn't finished sealing either of them, obviously.
So drywall screws will thread into the xps foam and hold for some uses ? Not to sound stupid, I know that expecting that using dry wall screws into foam would not support any weight. But they can be used to hold things together (no load usage).
rustytoolss wrote: So drywall screws will thread into the xps foam and hold for some uses ? Not to sound stupid, I know that expecting that using dry wall screws into foam would not support any weight. But they can be used to hold things together (no load usage).
lthomas987 wrote:rustytoolss wrote: So drywall screws will thread into the xps foam and hold for some uses ? Not to sound stupid, I know that expecting that using dry wall screws into foam would not support any weight. But they can be used to hold things together (no load usage).
Um. They will thread. But they won't hold really. For tacking together while glue sets they are fine. I used the to help hold my roof while it dried too. Like bamboo skewers. But slightly more clamping power if you gave them a cardboard washer. And don't over tighten them so they strip out.
dancam wrote:KCstudly- any particular reason for using cedar?
rustytoolss wrote:Can I use the PL to glue the foam to the 2x2's and the plywood ?
dancam wrote:I cant remember who i saw post a detailed description of drilling the holes in the foam and filling them with glue, but its out there
Andrew Herrick wrote:...did you experience any splitting with the cedar?
Users browsing this forum: Ambd30 and 7 guests
