tony.latham wrote:Do you guys have any suggestions or tips for anyone who wants to make a pop-up foamie in the future?
That open-box design as you know, is a problem. But if anything would work, fiberglass/epoxy instead of PMF. You could reinforce the stress points with extra glass.
But hey, you guys had a grand adventure in it.
Pmullen503 wrote:Big plywood gussets in the corners. Like 2x2 feet, glued to the roof and screwed to the embedded wood framing. Repair the exterior with canvas patches.
GPW wrote:Hey Dan , maybe we can all put on our thinking caps and help out with your dilemma ..??? For instance … Do you think the wood bracing made it too rigid when it might have done better if having more flexible … ??? We saw those videos of Rigid trailers coming apart , when a little flexing would have saved them … ( Just a thought )
tony.latham wrote:Do you think the wood bracing made it too rigid...
I'll argue that it's the flexing that caused the failure. It wouldn't have happened if it wasn't made from two open boxes which of course wasn't an option. The only way to make something like that work is to prevent flexing. Stiffen it up.
Torsion boxes are strong because they don't flex.
John61CT wrote:Yes, the lifting points' loads must be well distributed IMO with a rigid metal profile.
The way the cracking radiates from the lifting points makes it very likely that was the cause?
Pmullen503 wrote:Watching the video of the top lifting, I wonder if the air cylinders on four corners isn't part of the flexing problem. It looked pretty easy to rack the top from unequal lifting.
It should be possible to have it securely clamped in the down position to eliminate flexing it that's a problem. Maybe a removable brace to tie the back together while traveling and set/take down.
Pmullen503 wrote:John61CT wrote:Yes, the lifting points' loads must be well distributed IMO with a rigid metal profile.
Or a mechanism that guarantees all four corners lift together like the cable system in a pop up.
RJ Howell wrote:Pmullen503 wrote:John61CT wrote:Yes, the lifting points' loads must be well distributed IMO with a rigid metal profile.
Sorry, but I dis-agree with both you. Most of the lifts are done with spring loaded arms and no way are they 'balanced'. Look at the RTT's and see how they work. Granted most are angle lifts, yet some are still full lifts. No way can you release a clamp and even think it will go up equally. I don't see that as the issue here.
This lift-top looks like a 50/50 lift. Most are 75/25 or less. That makes them work well. With this, we're far beyond that and what can we recommend as a solution?
He has a pneumatic lift. My thought is it's under powered and requires regulators to balance the lift. How to do that with what he has? Come on folks.. We have a ME here that can assist in a add-on for him?
Pmullen503 wrote:In this case (lifting a box that fits over another) lifting the box straight, without racking is important. RTTs and most pop ups have soft sides so lifting evenly is less important.
In terms of something to fix the problem (assuming the problem is uneven lift) maybe a cable system at the corners that constrains the top as you lift it to keep it straight. So, pressurize the pistons and slowly crank out the cables to allow the pistons to lift. Crank down against some air pressure to lower.
pchast wrote:How about different door latches............. Cam locks.
Like a double hung window latch in design to hold things
stable?
Here is what I did to keep the rear from flexing side to side while travelling. I made a piece of aluminum for the door to fit a slot on the doorjamb.Pmullen503 wrote:Watching the video of the top lifting, I wonder if the air cylinders on four corners isn't part of the flexing problem. It looked pretty easy to rack the top from unequal lifting.
dancam wrote:RJ Howell wrote:[
What do you mean by a 50/50 or 75/25 lift?
dancam wrote:
So, with the lifting... we had loads of problems with that. Abs and pvc pipe is very uneven on the inside and my seals would seal for 3 inches of travel, leak for 2 inches, be too tight for an inch, then slide nice and seal, then leak too much to lift....
Personally, I'd can the hard piping and go flexible.
It also doesnt lift evenly because of the rear overhang. The rear cylinders have to lift more than the front and they are the same size
Here's where regulators would assist you. You can dial them in to lift the different weight equally.
Users browsing this forum: knova, twisted lines and 4 guests
