Cheap over foam flooring ideas
Re: Cheap over foam flooring ideas
Postby ghcoe » Sat May 08, 2021 10:30 am
tony.latham wrote:
I'm open to do anything to secure my wall...
In the video link you provided the guy was attaching his walls to an OSB (ouch) floor which I assume he subsequently (mechanically) bolts to his chassis.
Nothing wrong with OSB if it is protected well. I have done quite a few water crossings with the floor totally submerged in the water as well as being stored outside for the last two years. No problems at all. Yes I use a combination of clamping and bolts through the floor into the trailer cross members.
George.
ghcoe
