Another idea from the sketchbook ...
Re: Another idea from the sketchbook ...
Postby twisted lines » Sat Feb 25, 2023 12:10 pm
An old test on 1.5" cut twice, three 1/2 vs bent pretty well till it didn't.
Racking up; And Rapin foam
twisted lines
Postby GPW » Sun Feb 26, 2023 6:02 am
TL, Great idea !!! 8)
Postby twisted lines » Sun Feb 26, 2023 9:57 am
GPW wrote:TL, Great idea !!! 8)
I thought that two cut's may work, but when I pulled to see how eazy it may be to glue :thumbdown: The outside pre cuts? don't help
Yesterday I got 2 7/8" pink foam.
If today goes better then yesterday all I need are two tips
At just the right place; & the smoke from the same :thinking:
May be leather gloves and some, foam handles.
twisted lines
Postby pchast » Sun Feb 26, 2023 10:26 pm
Did you bend the pieces together or separately and then glue. I think you may find if you restrain the ends of the piece you're bending it will better conform to the curve. I've used that making wood forms with sheet metal binding the outside.
pchast
Images: 97
Postby twisted lines » Mon Feb 27, 2023 8:05 am
pchast wrote:Did you bend the pieces together or separately and then glue. I think you may find if you restrain the ends of the piece you're bending it will better conform to the curve. I've used that making wood forms with sheet metal binding the outside.
Only a 4’ wide cut test, while playing with it; pulling to test how to glue, snapped it. That piece is only squeezed like that.
twisted lines
Postby twisted lines » Wed Mar 01, 2023 2:24 pm
Is cutting the other way any better where the snap lines are?
The concrete is on top!
Didn't help :frightened:
snap lines.jpg (55.03 KiB) Viewed 976 times
twisted lines
Postby twisted lines » Sun Mar 19, 2023 9:05 am
I thought cutting the foam would be the hard part.
I think the bearings went first, day's & still not done :frightened:
twisted lines
Postby GPW » Mon Mar 20, 2023 4:56 am
Just a note : When bending foam to the extreme , the outside of the bend is most venerable to cracking (Tension) . So the easy thing to do is put some kind of tape on the outside , even cheap packing tape will take the tension loads and prevent cracking while bending . Fiberglass tape while more pricy works the best ... Even with kerfing' , tape works !!! ;)
Postby twisted lines » Tue Mar 28, 2023 2:58 pm
The 4' rule tells all, forward is the 10 lb'r
Behind it inside; 15'.
If you measure like a boat, within inches :lol:
75 wide.jpg (57.68 KiB) Viewed 871 times
twisted lines
Postby twisted lines » Fri Apr 28, 2023 10:15 am
GPW wrote:Just a note : When bending foam to the extreme , the outside of the bend is most venerable to cracking (Tension) . So the easy thing to do is put some kind of tape on the outside , even cheap packing tape will take the tension loads and prevent cracking while bending . Fiberglass tape while more pricy works the best ... Even with kerfing' , tape works !!! ;)
I kept this in mind yesterday; Thanks
Tape worked very well :thumbsup:
twisted lines
