Here's the current state of the inside. This is all about to change again of course. If you look right up near the front you can see where I pulled the outer covering between the foam and the metal on the trailer and temporarily stapled it to the deck. I'm going to trim all that and glue it to the inside fabric so the whole bottom edge of the foam will be wrapped from outside in.
You can see the bias tape joining the ceiling linen and the wall linen. Bias tape goes so nicely around curves and things so it made a much cleaner edge than I could have done lapping either to the ceiling or to the wall from the other.
I just went right over the windows and doors. This evening I'm going to cut them out and fold and glue down the flaps. Also all the little trim flappy bits.
I have to say when the outside was covered and I was sanding the inside I was REALLY worried about how floppy all my kerfs were. I am not worried now the whole front is very stiff.
