Bonnie , I’m so Happy for you
... as you have seen I’m rather "Large frame" and didn’t fit too well in the Nookery ... But you’re a perfect size for it , and it for you...
I know you’ll appreciate the Lightness of it , easy to handle and move around the yard if you have to ... Did it burn much extra gas towing it ... ? It did have a rather small profile behind that Big Truck of yours (noticed that as you were leaving .) ... Figured it wouldn’t be out in the wind much ... less drag ...
Too bad about the Bub, but just write that off as a learning experience... (I’ve had Many learning experiences
) But you still have a good axle, wheels and tongue bar ... Another project for later ...
You asked about a sealant ... We tried 3M 5200 Marine sealant on the FS , and it sticks like
CRAZY , seals everything ... takes several days to cure , but what ever you use it on, it isn’t going anywhere... Good Stuff!! , even in our Humidity and frequent rain ...... a bit pricy to use just around the AC door ... Maybe you can share it with someone else ...
