cpowell243 wrote:OP,
I considered folding the upper walls down on the inside but had to go up since I wanted access to the galley from the outside when I swing the galley around to the back. I did not think about the idea of folding doors up and actually storing them outside of the main body. That might've worked but I think I'm OK with the current design. If they come loose from my home-grown brackets in transit they simply sit on the interior wall.
My problem now is that the gas springs are lifting my hinge up and creating a gap at the hinge point. I'm no trying to figure out a way to add a set of external latches to pull the hatch down to the main main body. Had to pull things apart to gain access so not a pretty picture. Need to add hard points to attach. The other problem I face if I can get these in place is how will the latch work in both the raised and closed position since the will sit at different angles. Other ideas? Frustrating since I want to get started with the interior but have to get this thing weather-tight.
Wish me luck.
Ch
Users browsing this forum: Bing [Bot] and 6 guests
