GPW wrote:If you used Masonite or plywood , both would be a bit heavy for under a canvas skin . Surely a bit of overkill ... Strong for sure , but ...
Remember the Old Timers skinned their trailers with Masonite , worked for them ...
GPW wrote:" maybe 10 pounds? “ ... Maybe more ...??? if you covered everything with “utility panels ” you wouldn’t need an fabric skin on the outside ... Just give it a couple coats of Aluminum paint, like the old timers did ...
At the HD yesterday ( buying lawnmower parts and generally just looking around ) we noticed a couple rolls pf protective brown paper ... one was thick paper , the other , was really Thick paper ... http://www.homedepot.com/p/Ram-Board-38 ... /202823781
greygoos wrote:Hi I brought this up in an earlier thread regarding new skins for Foamies and it wasnt well received but I am going to suggest it again and would appreciate comments. How about Expanded PVC foam? It is lighweight and inexpensive. I have thought about using it for an outside skin and or under canvas.
