Thanks again for the compliments, all.
Bill (Wagondude), The idea is to use the hinge on the cabin side clamping the excess flap of canvas (to be trimmed off later), and just fold the hatch side of the hinge back on itself. Do I need to worry about the glue wicking across the gap between spars?
LFH, I’m probably going to use the same material that I make the fenders from. Most likely .060 mill run aluminum, although a nice big engine turned pattern would be really nice. More likely I will have them powder coated the same metallic silver that I used on the rear galley floor edge and hatch actuator brackets. Diamond tread would be another option, but Karl seemed to think that it wouldn’t fair as well in the break press, and I don’t plan on using any trim on the edges, so don’t want to worry about partial diamond nubs at the cut edges
OP, Okay. What would be the advantage of the strips over using a thin sheet? Just the fact that I can get them out of the stock I already have on hand? (I think I may have just answered my own question!)
Maybe slather knocked down GS on, then clamp a piece of plywood to the side wall with a release agent; let it vent out the top? Again, probably more fraught with trouble than just using spackle (filler) and sanding back.
Tony posted a link to a Rutan composite instruction manual over on your Foldable Foamie build. I didn’t want to clutter up that thread with my thoughts related to my build, so I will comment here. I found it interesting (and a little discouraging) that they call for a micro slurry (50/50 microspheres and epoxy by volume) between foam and the first glass ply. This means that the cloth would need to be laid into the wet coat, rather than first positioning the cloth and wetting out thru the weave. All of the kayak builds I have looked at wet thru the plies, but I guess the difference is that there is less chance of delam with epoxy soaked into wood than with foam, so keying into the coarsely sanded foam is more critical.
The West Marine system says to avoid trying to place large sheets in a wet bed because of the difficulty placing larger sheets, and not wanting to shift things once they start to cling. So I guess if I go with glass I would be building a boat, not an airplane.
The 36 grit prep seems very rough to me. I guess they want a really good key in, and hence the micro slurry, but I would expect to pull out some large chunks at that grit, even tearing/crushing some voids into the foam, ending up with a much heavier buildup. I have had that happen when pushing coarse grit. Sometimes the grit grabs into the foam and then tears out chunks or pushes the foam to the side crushing and tearing jagged pits, rather than grinding away smaller particles at the surface. They do say that there is a difference between the airplane quality foam and insulation foam, so maybe that makes a difference in the ability to use such a coarse grit for surface prep. Testing is indicated.
I can see where your (OP’s) slitting technique might be an advantage to the slurry in some ways, but can't imagine it working well with some of the fillers used to make the foam fair before starting to glass, especially not the spackle I have been using. I would be concerned that the spackle might break up. Maybe more testing is needed.
One more thing I don’t want to forget before making a final covering decision is the difficulty laying up epoxy on vertical surfaces. I can keel the cabin over some without too much trouble (as I have been doing), but to lay it over on its sides to allow a completely flat layup of the walls would get to be an involved process with considerable risk of damage.
Too many things to consider.
Anybody catch the lunar eclipse tonight? Pretty cool.
