I kind of crossed over on the PMF vs. FG thread tonight, so may be repeating myself here.
Tonight we made a hardware store run for a few misc. items and I helped Karl pick out some 4x4's for a project he is working on. Once back at the shop I got to work clearing off the work bench and cleaning up a bit. Then I dismantled and reclaimed the plastic sheeting from my makeshift vacuum bag set-up. Used the 6mil plastic to line the bench top for the upcoming covering operations, since I was thinking that I had pretty much decided on going with epoxy and glass.
One "small" issue I would have to deal with is the fact that I coated the edges and under side of the floor with TB2 as a sealer. It has been scuffed with 100 grit, but from what I have been researching more tooth is desired when mechanically bonding with epoxy, and the cedar probably wants some special handling as well.
I even made up a nice mix ratio chart for the epoxy, brought some old pallet topper cardboard sheets to use as drop cloth, and some stretch wrap for masking and lay-ups.
Of the two canvas test panels that I primed last night, one of them curled the canvas away from the foam a bit along one of the unwrapped edges, but the other sample seemed to come out really nice. Just had to knock down all of the little canvas "hairs" poking up thru the surface of the primer using the small hand block. The primer seemed to make the canvas even more resistant to denting. I could still push my finger into it easier than the 2-ply glass (which is actually pretty stiff), but it seems to spring back more readily now without leaving a visible dent, even on the large radius edge. I brought the two samples with me to show around at work and see what the guys think.
Man, here I was thinking that I had committed to the epoxy and FG, but I'm waffling again.
Interesting, too, that the poll is tied at 50/50.
