GPW wrote:Yes , don’t be constrained by standard thinking …a good bit of the floor strength comes from the trailer’s metal crossmembers. You don’t really need that much , you’re only attaching foam walls to it … Our latest fascination is a "Board floor" which can be very practical , light and no chance of delamination or going mushy … If you can find some nice 5/4 Cedar fence boards , I think that would make a fine floor with a little extra framing , and not break the bank either …
GPW wrote:LC , for Thrifty reasons , if you soak that OSB wafer board with "the mix" till it won’t take anymore , and use a drip edge , it should last forever…. We found the reason RV floors fail is because they don’t treat them with anything to waterproof them … Therefore they soak up water like a sponge … and then you have to bring them in for expensive repairs … ( See: "Money Pit” and “scams “ )
